Author Topic: Bluebird K7- 1/24th scale  (Read 5130 times)
Ben Tickle
« on: February 08, 2011, 01:07:57 pm »
Hi All,
I was thinking of purchasing bluebird k7 (1/24th scale) of speedline models. I was just wondering what brushless motor you would all advise for this model?
Ben :-))
ooyah/2
Re: Bluebird K7- 1/24th scale
« Reply #1 on: February 08, 2011, 04:12:14 pm »
Hi Ben,
Have you seen this article by Ernie Lazenby in Astec web site  http://www.astecmodels.co.uk/ernies-set-ups-3.htm  Might be of help to you.
I have a K7 to 1/12 th scale from Touchwood with brushless motor  see You-tube   BRUSHLESS BLUEBIRD.
George.
Ben Tickle
« Reply #2 on: February 08, 2011, 04:52:02 pm »
Hi George,
Thanks for your advice. I have read that article which you reccommended. As you have one of these, what motor would you use and where does it come from?
Ben :-))
ooyah/2
« Reply #3 on: February 08, 2011, 08:40:31 pm »
Hi Ben,
The motor that I use is from Prestwich Model Center (  http://www.prestwich.ndirect.co.uk/brushless.htm  )
Motor is Bl5- 2845,   2700 kv with 70amp E.S.C although I think that a 60 amp would do, I run on 7 Sub "C"  cells x 4300 mamph  8.4 volt.
But remember my K7 is 1/12 th scale where as 1/24 th is the one described by Ernie in Astec.
I just doubled up on all Ernies dimensions.
I have seen Ernies 1/24 th scale K7 run and it's lightening fast, best of luck,
George.
Ben Tickle
« Reply #4 on: February 08, 2011, 09:38:08 pm »
What motor does ernies k7 have in it?
Ben :embarrassed:
ooyah/2
« Reply #5 on: February 08, 2011, 11:47:11 pm »
Hi Ben,
If you read the write up at the part on water cooling he mentions a motor ( 400 ) I can only assume that it's a Graupner 400. which I think can be had from Astec.
George.
nick_75au
« Reply #6 on: February 09, 2011, 05:57:14 am »
Hi Ben,
From what I gather its a 6 volt speed 400, which has a Kv of around 2700-3000. run on 8.4 volts  gives a no load speed of 25000 rpm or so. I would run a 1000-1500 Mah 7.4 volt lipo and a 3500 Kv motor, this will be lighter than the set-up described at the aztec site O0
Use the same 29 mm prop.
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9257
or similar.
Nick
Ben Tickle
« Reply #7 on: February 13, 2011, 08:31:18 pm »
Hi All,
I have done a bit of research into brushless motors. I have found one on giant cod that is 20 X 40mm and 14 amps. Does the ampage mean anything?
Ben :} :}
ooyah/2
« Reply #8 on: February 14, 2011, 09:27:34 pm »
Hi Ben,
I am not sure about the motor you mention but I see that you have asked Giant Cod on the brushless motor.
I have one of them and it's rated at 3600 kv and in my opinion it's much to heavy for the 1/24 th scale K7.
Have you had a word with Allan at ASTEC he has all the details on Ernies 1/24 th K7 and I am sure will be able to supply all that you need.
George.
Page created in 0.012 seconds with 15 queries.
