Author Topic: Model boating in salt water.  (Read 4038 times)
sandy1000
« on: March 18, 2011, 11:27:51 pm »
What is the general feeling about model boats in saltwater? There is a huge empty marina near where I live which is part of a maritime complex which has gone broke. It is perfect for model boat. Access is acceptable to the administrators. But it is directly connected to the open sea, so the water is salty. Would there be problems with salt in bearings for example. Are there any other salt issues that should be considered?
unbuiltnautilus
Re: Model boating in salt water.
« Reply #1 on: March 19, 2011, 10:01:26 am »
Our local lakes in Portsmouth are all salt water, we have two clubs running on it with no complaints. Basic rules, keep the water on the outside of the model. Keep all plugs and sockets out of the bilge of the boat as salt water will eat your electrical contacts for lunch if they get wet. In the summer, any water splashes on the upperworks will dry out to salt crystals, this can be remedied with a fresh water wash when you get home. We even run submarines in the salt water, however, you are limited in their operational depth and the subs need to be fitted with an insulated aerial. Avoid mild steel fittings, use brass or plastic. Look after the model after every run. :-))
alan colson
  • I Just Dabble In Model Boats
« Reply #2 on: March 19, 2011, 10:21:19 am »
I have run models on the odd occasion in salt water, when I get home I try to run them in fresh water in the bath (test tank) and oil or grease shafts and rudders.
Alan
sandy1000
« Reply #3 on: March 19, 2011, 11:25:29 pm »
Thanks for the advice.
« Reply #4 on: April 08, 2011, 09:32:09 am »
I've sailed in virtually nothing else since I started.  Just pay more attention to regular servicing, and make sure that the wet stuff stays on the outside.
john s 2
« Reply #5 on: April 08, 2011, 01:52:10 pm »
Salt water does have an insidious way of corroding things. Ive had the soildered blades on a prop fall out.
Moral is total wash down after use. John.
irishcarguy
« Reply #6 on: September 08, 2011, 08:21:27 am »
For protection of electrical connectors try automotive dielectric grease it is used on autos to stop resistance in connections to computer compontents At least thats what is named in Canada. Also works well on Joseph Lucas prince of darkness connections Mick B. Look up Permatex dielectric grease on Google.
Mick B.
treeboa
« Reply #7 on: September 08, 2011, 08:36:28 am »
dont forget to flush any cooling systems through after use
« Reply #8 on: September 08, 2011, 11:20:53 am »
 Look up "Vaseline" at the Chemist.
  Regards  Ian.
Page created in 0.013 seconds with 18 queries.
