Author Topic: After Run Oils?  (Read 1907 times)
BJ
After Run Oils?
« on: March 30, 2011, 07:42:14 pm »
A flyer friend has just suggested that Power Transmission fluid is acceptable lieu of conventional After Run Oil in a Nitro engine.  Personally, I like to use a thin (sewing machine) type oil instead of after run oils or WD40 type fluids.
Anyone got any comments on this?
I did find this one one web site....
Heavy-duty, high performance
Control of rust and corrosion
Foam prevention
Seal compatibility
For use in transmissions, final drives, and wet brakes of equipment
Excellent friction properties, gear protection and resistance to oxidation
gregk9
    • Chasewater Model Boat Club
Re: After Run Oils?
« Reply #1 on: March 31, 2011, 10:55:52 am »
Personally, id suggest using a 0w/30  car engine oil, as afterall, this is designed for engines and use in engine cylinders.  transmission oils and ordinary oils can be attacked by the residue left by combustion in the engine cylinder, causing more harm than good.
this stuff is thin enough to be recommended for  turbo engines and their high temperatures way beyond what an r/c will reach and also contains enough addatives to reduce the corrosive effects of combustion residue inside the motor.
Ok, so you may have to buy a 1ltr bottle, but think how long it will last you as compared to the high price you pay for a minute little container of sewing machine oil.
Best wishes.
Steve. G.
Treasurer & Membership Secretary:  Chasewater Model Boat Club
http://chasewatermbc.blogspot.com/
