Pages: 1 2 3 4 5 6 7 [8] 9 10 11   Go Down
Author Topic: Glen's build of an Armidale  (Read 85178 times)
brianB6
Re: Glen's build of an Armidale
« Reply #175 on: October 18, 2011, 08:02:10 am »
Thank you for the parts, Steve.
I had some fun today making the mountings for the Sat. domes.  O0
The distance between the roof and the underside of the domes is 10 mm.
The Sat-tel dome support is not quite right, I am sure, but I could not get any clear photos of the full size one.  <:(
They still need finishing off.
Glenedge
« Reply #176 on: October 18, 2011, 09:28:11 am »
Hi Brian
The stbd side dome looks ok, here is a pic showing the port side that has a cone sort of thing underneath. Hope it helps.
Glen
brianB6
« Reply #177 on: October 19, 2011, 01:07:42 am »
Hi Glen
In hindsight I should have made the bottom shape in epoxy filler and then cut it to fit the supporting fins.
Now I have to fill in between the fins which will be more difficult and not as neat.  {:-{
My original reasoning was that the 'filling' does not go all round the dome and appears to finish at the curved fins.  It is not visible on the rear view.
Trooper63
« Reply #178 on: October 26, 2011, 08:16:11 am »
Looks like I'm getting a ride on board Bundie this Sat.  Any photos needed?
brianB6
« Reply #179 on: October 26, 2011, 08:54:47 am »
Thousands.   O0 :embarrassed:
Lucky lad.
RaaArtyGunner
« Reply #180 on: October 26, 2011, 11:16:45 am »
Is it just a rumour, or are the Armidales, due to be replaced by multi purpose vessel under construction? <:(
Trooper63
« Reply #181 on: October 26, 2011, 09:53:18 pm »
The Australian Customs Service is having built a modified Armidale Class by Austal over in Perth.  This may be the source of the 'multi-purpose' vessel.  The ACS boats will be Bay Class vessels.
It seems to be a management process where the aluminum boats are replaced at around the 7yr mark.  Not sure how old the first ACPB.
Peter Fitness
« Reply #182 on: October 26, 2011, 10:27:07 pm »
The first of the class, HMAS Armidale (ACPB 83), was commissioned on 24th June 2005, and the last, HMAS Glenelg (ACPB 96) on 22nd February 2008.
More info here http://www.navy.gov.au/Armidale_Class
Peter.
brianB6
« Reply #183 on: October 26, 2011, 10:45:21 pm »
Sorry Trooper  {:-{
The new Customs boats will be the 'Cape' class, The 'Bays' are the existing ones.
8 to be built starting in 2012.   Slightly bigger than the Armidales and no big gun at the moment.
Only renderings on the Austral website;-
http://www.austal.com/en/media/media-releases/11-08-12/Austal-Awarded-Cape-Class-Patrol-Boat-Contract.aspx
There has been no discussion on a replacement for the Armidales, as far as I know, and the Navy would surely require more than 7 years service from them.  :embarrassed:
RaaArtyGunner
« Reply #184 on: October 27, 2011, 04:13:01 am »
Thanks guys, it looks like the media got it "right" ? once again.
Obviously mixed up Customs with RAN >>:-( >>:-(
brianB6
« Reply #185 on: October 27, 2011, 06:48:28 am »
Mmmm! Made a spare mast.   I wonder if it would fit?  <*<
Trooper63
« Reply #186 on: October 27, 2011, 07:58:49 am »
Oops, yep Cape Class.  Been on a few of the xxxxx Bay Class Boats, and begood to see a larger and hopefully more stable boat.
Glenedge
« Reply #187 on: November 11, 2011, 08:44:12 am »
Latest pic of some work on the port bridge wing. :-)
Glen
brianB6
« Reply #188 on: November 11, 2011, 09:14:52 am »
Coming on nicely Glen.
I suppose I should add my latest bit.
I bought a 21 mm. ball bearing to fit inside the gun base for $5.50 which I thought was quite reasonable.
The gun will now turn with the slightest effort.  ;D
However work has come to a halt as we had 75 mm. of rain two nights ago which resulted in my workshop and my wifes studio being flooded by 17 cm. of dirty water.  <:(
brianB6
« Reply #189 on: November 11, 2011, 09:24:36 am »
Mind you, our latest family arrivals were well above the water line.  %%
Proud father showing off 4 of his 5 offspring.  %%
« Reply #190 on: December 12, 2011, 06:57:09 pm »
Have you done any more Glen ?
Glenedge
« Reply #191 on: December 14, 2011, 09:35:21 am »
Hi Dicky
 havent done too much to the boat latley, been out chasing gold before the wet season gets here. Once the rains start then i will get back into the model.
 Glen
Glenedge
« Reply #192 on: January 10, 2012, 08:40:13 am »
Hi Brian
Whats the chance of you whipping up a brass barrel for me when you have a spare minute??? Looks great :-)
brianB6
« Reply #193 on: January 10, 2012, 10:25:39 pm »
Hi Glen
How far back do you need to go?
I made mine in several pieces.   Thin part of the barrel, thicker part, Sight? all in brass.  All turned on my big Makita drill held in the vice.   I used files to get the profiles.
Not the best way to use a drill!!!
The rest was made in perspex and the sight support in car body filler.
brianB6
« Reply #194 on: January 11, 2012, 03:04:10 am »
Is this ok?
Where it fits into the rest of the barrel is 2 mm. dia. I can reduce it a bit.
Glenedge
« Reply #195 on: January 12, 2012, 08:57:34 pm »
Hi Brian
 The barrel is all I am chasing.
Cheers Glen
RaaArtyGunner
« Reply #196 on: January 12, 2012, 10:19:26 pm »
Is this ok?
Brian,
Looks like I have found another use for my Makita
brianB6
« Reply #197 on: January 13, 2012, 12:42:00 am »
Take the cuts very lightly or you may damage the bearings, they are not meant for much side load.  <:(
You may find it easier to run the drill backwards.   I can reverse the direction without removing the drill from the vice.
I have some favourate fine files from Bunnings (B & Q for those up the other way) and 1/2 round needle files.   They need to be cleaned of swarf every now and then with a miniature wire brush.
RaaArtyGunner
« Reply #198 on: January 13, 2012, 10:40:57 am »
Brian,
Thanks for the advice, my Makita is a heavy duty two speed hammer drill.
Nonetheless good advice.
Glenedge
« Reply #199 on: January 17, 2012, 01:59:49 am »
brians barrel on Steves gunmount.  :-))
 Glen
Pages: 1 2 3 4 5 6 7 [8] 9 10 11   Go Up
