Author Topic: stuck again  (Read 3670 times)
darrencuk
stuck again
« on: April 18, 2011, 02:08:50 pm »
Hi I was just wondering if u guys can help with my universal coupling question :s I'm going to be running a 3.17mm motor shaft so I have brought a 3.2mm coupling for the prop end I am looking at a shaft on cornwall model boats its 68 mm long 4mm thick with the inner part at 2mm which the prop screws on to so I understand I need a 2 mm coupling my question is will this be safe using a 3.2 up front and bringing it down to a 2mm reason I'm asking is 68mm is spot on leangh I need just worried about lowering size at back hopefully one u guys out there can help u have been very helpfull so far thanks again :)
Re: stuck again
« Reply #1 on: April 18, 2011, 02:52:04 pm »
Sorry, cant really understand what you are asking. {:-{
All you need to know for a universal coupling is the diameter of the prop shaft and the diameter of the motor shaft.
wartsilaone
Re: stuck again
« Reply #2 on: April 18, 2011, 02:58:44 pm »
I tend to agree with Dicky. I can't see any problem as long as you have the couplings to match the motor and prop shaft.
pugwash
Re: stuck again
« Reply #3 on: April 18, 2011, 03:23:12 pm »
I think what is worrying him is the torque involved reducing from 3.2mm to 2mm - I dont think there should be any problems
providing you haven't got an ENORMOUS motor on the end of the shaft.
Geoff
john44
Re: stuck again
« Reply #4 on: April 18, 2011, 03:25:33 pm »
You havent said what size /type of propeller you are thinking of using.Also on what type of boat,
 If for example it is going on a tug-boat with a large prop I would be a bit worried.
john
Re: stuck again
« Reply #5 on: April 18, 2011, 03:58:32 pm »
Sounds like a 385 so it should not be much of a prop on that on a 2mm shaft
darrencuk
Re: stuck again
« Reply #6 on: April 18, 2011, 07:30:33 pm »
Its a custom built boat I'm trying to cut down on room as its a small boat I'm running a 540 motor I was thinking off running 30mm prop 2 blade or 3 don't no yet was just worried about tourque
Re: stuck again
« Reply #7 on: April 18, 2011, 09:00:08 pm »
2mm is rather small for a 540 motor.
Re: stuck again
« Reply #8 on: April 19, 2011, 06:46:13 am »
Senior moment from me sorry
Transposed my twos and threes
385 2.3mm 540 3.2mm
I agree with Shipmate 60
2mm shaft is too small for a 540
darrencuk
Re: stuck again
« Reply #9 on: April 19, 2011, 10:26:09 am »
ok thanks What prop shaft would u run in your opinion then still learning
Re: stuck again
« Reply #10 on: April 19, 2011, 10:33:17 am »
A standard 4mm propshaft will be fine.
If the length is crutial contact MMB as Mark will make shafts to an exact size   CLICK HERE
darrencuk
Re: stuck again
« Reply #11 on: April 19, 2011, 11:28:06 am »
So just so I understand 4mm prop shaft will be 4mm center part so I will need a 4mm coupling but the outer shaft of the prop shaft the part that fits in the hull is 6mm and I will need a m4 size thread prop?
Re: stuck again
« Reply #12 on: April 19, 2011, 11:36:54 am »
Right  :-))
darrencuk
Re: stuck again
« Reply #13 on: April 19, 2011, 12:32:07 pm »
Do u think the person u have said about making me a shaft could make a 4mm one in the length 100mm
Marks Model Bits
  • No Mustang Mark
  • http://marksmodelbits.com/
    • Marks Model Bits
Re: stuck again
« Reply #14 on: April 19, 2011, 01:15:41 pm »
Hi, yes we have them in stock give me a ring and I can help you more
Mark
I HAVE NOT FAILED, I HAVE FOUND 1000 WAYS THAT DON'T WORK.!!!!
darrencuk
Re: stuck again
« Reply #15 on: April 19, 2011, 05:20:17 pm »
Just like to say a big thank u to everyone who helped me I now have a shaft on order from mark very happy thanks guys this site is very helpfull
Page created in 0.02 seconds with 18 queries.
