My neighbour came by with a large cardboard box, and said " You do modelling don't you?" He then gave me said box announcing it had a Heli that he had bought at a Boot Sale and could I get it going as he fancied flying it in his garden!!!!!!!!
I looked in the box and there was a heli, not Twin Rotor but one with Flybar and Swash Plate and Tail Rotor,Gyro, etc. a real Heli.Rotor diameter is 55 cms. Tx is 6 channel, has Rates and two Trims above each stick apart from normal Trims. No body but all is there. Charged the Batteries on Tx and Heli, cleaned it up, checked all the plugs etc, and found. No On/Off switch! Now what? It seemed that when you plug in the Heli Battery that switches everything on, HHHMMMM!!! I do not like that! Set the throttle to stop and switched on Tx and plugged in Heli Battery. Nothing. Then the Gyro light lit up. I jiggled the sticks and both servos did their stuff, but no Motor. Then the Tail Rotor ran and a few seconds later the Main started. The throttle works, and it stops with closed throttle stick, but where would I find out where the starting settings are for the Flybar and Main Rotor Pitch?The Flybar paddles are obviously incorrect, one is nearly at 45° to the axis. This is definitely no Beginners Model, so what would any of you do in similar circumstances? Comments, of all kinds(!) welcome!
