Not sure where to post this, so please move to the appropriate section.........
A brief history...I purchased a "flying fish" from ebay (
http://www.qi-remote-control-toys.co.uk/catalog/product_info.php?products_id=66), as a tester to see if I liked the rc hobby. I had a few hours of fun with this boat, but wanted more speed. I went out and purchased a couple of offshore warriors from Astec. These have been great fun to scream around the lake with my son for the last year or so.
The flying fish has been sitting around gathering dust, so I decided to strip it out and add a brushless motor and rudder. Took it to the lake on Sunday for the "launch" and all is not well! Plenty of revs, but practically zero forward movement. Obviously there is something wrong with the setup of the boat so would like some help with what to change?
Why did I chose to modify the flying fish?? - I like the look of the boat, and it was a cheap, quick way to learn some building techniques.
Basic setup:
3600Kv brushless (
http://www.giantcod.co.uk/bl2845-3600kv-watercooled-inrunner-motor-p-404992.html)
60A ESC
3S Lipo
Boat is just under 1m long, and around 300mm wide.
Weight with lipo is 2.2Kg
CG is around 40% from rear, so this is a little high. As the boat is so light, I was going to just add more weight to back end?
The depth and angle of the original flying fish props have been copied, but, because the motor is now a single centre mounted one, I think I should have mounted it deeper (I think the "V", blocks the prop)?
I bought a 31, 34 and 38mm prop from Giantcod (cheap to try different setups), but none really made any difference.
I have attached some pictures so you can see the basic layout of things.
Any help and comments will be greatly appreciated.
