Author Topic: Moving large model ships  (Read 7217 times)
sandy1000
« on: July 11, 2011, 12:45:56 am »
Are there any clever and effective ways out there for moving heavy and large model boats - from the car to the water and into and out of the water? I have a small folding trolley cart for lowering smaller boats down vertical slopes but the big boats are another story. I was at a funeral recently and the coffin was wheeled along on a cart which could be raised and lowered. Expensive, cumbersome and slightly morbid however. Any suggestions appreciated.
Re: Moving large model ships
« Reply #1 on: July 11, 2011, 01:05:47 am »
Sandy1000  >>:-( stay away from the funeral parlour  >:-o those coffin trolleys are 24 volt DC with self contained hydraulic systems
However they were designed by accountants  >>:-( <*< who scrimped on the cylinders as they chose ""phasing cylinders" ........just like the types used on VALMET shipping container carriers
The rod side discharge on the first cylinder is naturally of smaller volume on the blind side .....so.....the 2nd cylinder is of smaller bore.....then the same  applies to the 3rd  & 4th cylinder
If any one of the four cylinders suffers from internal bypass the coffin can tip & fall from the trolley.......now you wouldn't like that if your large heavy vessel was suspended above....... <:( .....Derek
sandy1000
« Reply #2 on: July 11, 2011, 04:40:43 am »
Thanks for that. Any other ideas? The boat needs to be lifted from the car, carried to the water, held at waste height, for final preparation, the lowered onto a wheeled launch ramp and later the process is reversed for departure.
More Coffee
« Reply #3 on: July 11, 2011, 04:50:09 am »
I have the same problem ...48" Mister Darby..plus anothet 40lb combined of battery and ballast
theres no other wat to put it
"brute force and ignorance  <*<" with a little finesse.  :kiss:
RaaArtyGunner
« Reply #4 on: July 11, 2011, 05:13:21 am »
In advance, sorry guys couldn't help myself, but a boat trailer springs to mind  %) %) %)
wartsilaone
« Reply #5 on: July 11, 2011, 06:56:52 am »
Patrick Henry
« Reply #6 on: July 11, 2011, 07:38:03 am »
One of our AMS members has a model of the USS Bowfin which measures 12' (144") in length and 5' (60") in the beam, and weighs far in excess of a quarter of a ton (minus ballast).
He transports this monster on a custom built trailer behind his car, and launches it like a full size boat...ie, by reversing the trailer into the lake down a slipway and floating the sub off. To land the thing, he drives the sub into position just behind the trailer and then pulls it back up and onto the trailer by hand.
This beast will be at Brighton Modelworld Show next year, by the way...
boatmadman
« Reply #7 on: July 11, 2011, 08:45:09 am »
tassie48
« Reply #8 on: July 11, 2011, 10:16:33 am »
I use a extension ladder inside my trailer to move my models allows them to side out and a 12 volt winch pulls them back up on the extension ladder roller skates wheels run up down the ladder  and a custom made trolley slips in and out of the water tassie48
sandy1000
« Reply #9 on: July 11, 2011, 10:38:23 am »
How about a modified scissor lift table?  http://www.rotairsystems.co.uk/liftmate_scissor.html
Or a modified motorbike lift: http://www.workshopping.co.uk/category/motorcycle-lifts/488/?gclid=CJPMk9bl-KkCFcRO4QodwFVaWA
Ian
The scissor lift table are ideal I will look around locally for something similar. The wheels on the motor bike affair are too small for the sandy and roughish approach to the water. Thanks.
sandy1000
« Reply #10 on: July 11, 2011, 10:39:41 am »
Any chance of a picture? Regards.
boatmadman
« Reply #11 on: July 11, 2011, 11:25:31 am »
This might help as well,
http://www.engineersedge.com/mechanics_machines/scissor-lift.htm
Also, you could use a 12v motor driving a lead screw to raise and lower the table.
Ian
wartsilaone
« Reply #12 on: July 11, 2011, 11:58:43 am »
When the paramedics get to the hospital and they get the trolley out of the back of the ambulance the trolley legs complete with wheels fold down and lock in automatically. If you can find one of these, maybe it can be converted to carry a boat.
Ali.
Bryan Young
« Reply #13 on: July 11, 2011, 04:28:05 pm »
I don't know what you call "large", but at least one of my models weighs in at nearly 120lb (on the water), and another one or two are in the 90lb range. I have to transport them in a trailer. But getting them out of the trailer and into the water is really quite easy.
The models are made so that interior access is large, and so spring loaded "chest" handles can be fitted. The empty "hull" section is then easily carried to the water. Then the batteries and ballast are added ....and then the "top hamper" plonked on. No individual part weighs more than 30lb. BY.
Notes from a simple seaman
sandy1000
« Reply #14 on: July 18, 2011, 12:11:57 pm »
Also, you could use a 12v motor driving a lead screw to raise and lower the table.Ian
I have come back to this post as I am considering trying to make my own. There are plenty of lifting devices, scissor lifts etc out there but they usually have small wheels and what I want is something that has:
Large tyres to go over rough terrain down to the water's edge.
Low profile to fit in the car (large tyres notwithstanding)
Raise and lower capability
Water resistant ie allows rolling down into water for boat to float off
Also needs to be steerable. I knocked up a launching trolley out of slotted angle iron but found it awkward to steer. Also tyres are too thin, even though I doubled them up.
Arrow5
« Reply #15 on: July 18, 2011, 12:39:17 pm »
Mobility scooter wheels too small ? They are available in various sizes and are pneumatic.
..well can you land on this?
More Coffee
« Reply #16 on: July 18, 2011, 12:45:53 pm »
This is how Stena does it..
slug
« Reply #17 on: July 18, 2011, 08:52:46 pm »
how about a car engine crane on bigger wheels you can get lightweight ones  just athoughtslug
slug
« Reply #18 on: July 18, 2011, 09:11:25 pm »
machine mart do a sack truck that could be handy nocst12 slug
sandy1000
« Reply #19 on: July 20, 2011, 01:43:19 am »
This is for small boats, epecially for vertical edges.
For somewhat larger boats the trolley (only $29.00 at the local store) laid down and with a handle fiitted into the plastic tube is another approach while the upgraded launching trolley is a limited method - hard to steer, wheels too thin.
