Author Topic: Planet 2.4gh radio system  (Read 3780 times)
yorkibob
« on: July 17, 2011, 06:55:52 pm »
I have a Planet 2.4 radio system and I have a question for you experts out there. Is it possible to have two receivers tuned in to one TX? - heres' why I ask, I want to sail two models using one TX at the same time, one using the left hand TX controls on Chanel's 1&2 and the other boat on the right hand controls on Chanel's 3&4 If I try to tune both receivers into the TX at the same time will this idea work?
Re: Planet 2.4gh radio system
« Reply #1 on: July 17, 2011, 06:57:11 pm »
In a word YES.
john44
« Reply #2 on: July 17, 2011, 07:19:44 pm »
I second that
john
« Reply #3 on: July 17, 2011, 09:32:52 pm »
But you need to be brave to use it that way!!
yorkibob
« Reply #4 on: July 18, 2011, 08:00:42 pm »
thanks for that guys' Ill' give it a go  -  Bob
unbuiltnautilus
« Reply #5 on: July 19, 2011, 09:37:22 am »
Further to the previous responses, we have modified a set to operate four separate models, not the manouevering functions, rather the 'special' functions. We are fairly sure the modifications have invalidated the warranty!!
JayDee
    • JOHN DOWD
« Reply #6 on: July 19, 2011, 12:56:08 pm »
Hello,
Very impressive !.
What have you done and how well does it all work.
Four models ? what are they ?.
John.   :-))
http://www.john-dowd.
rmaddock
« Reply #7 on: July 19, 2011, 12:59:10 pm »
I want to know what the big, red switch on top does!  :o
unbuiltnautilus
« Reply #8 on: July 19, 2011, 01:39:02 pm »
The last photo shows a brown box top right, this is one of four such boxes built. they are designed to drop into one of our Pyrotechnic equipped models and operate the bangs and flashes. Each dial controls a servo with either 6 or 10 positions available, while the red switch on the top of the set fires the pyrotechnic effect once it is pre-selected with the dial. Each box is allocated a 'dial' channel and shares the two position red switch channel. This gives us four seperate channels to select with ( in four seperate models ) with a shared firing function. Each box has a 9.6v NiMh battery fitted as well as an arming and test circuit, plus the neccessary connectors to hook into the individual model. The boxes can be dropped into any model big enough to accomodate them, we may also retro fit them into our 1/16 scale WWII village for our amphibious display next year (if we have any allied tanks left by then!!).
So far we have tested them along side each other with the transmitter about 40 yards away and through a brick wall and everything was fine. The units have only recently been completed and have not been to sea yet. The 10 function box is destined for my SS Ohio, however, that build is a bit behind schedule so the first unit may be fitted to one of our merchant ships which is under 'new management' and may want a ready use control unit for his bangs...
JayDee
    • JOHN DOWD
« Reply #9 on: July 19, 2011, 04:08:11 pm »
 Hello,
  BRILLIANT !!!
 John.   :-))  :-))  :-))
