Is it possible to make the frame [normally made in brass] from 6mm thick high impact polystyrene, using brass bearings for the shafts to run in.
the bearings would be glued in to the styrene frames, and the initial shaft speed would be about 2500 rpm turning two lay shafts at a reduction of 2.5 ; 1.
i have the technology and machinery to make it all, but just wonder whether after going to all the hassle the hips would melt around the bearing holes.
i know some will argue for and others against, but would like to hear from someone who has actually made one, please, and did it work or did it melt
i would like one similar to that in bill's Arun lifeboat, but in plastic.
cheers,
neil.
