Author Topic: Connecting the propeller shaft to the motor  (Read 2725 times)
WelshBuilder
« on: July 24, 2011, 01:31:09 pm »
What do you use to connect the motor to the propeller shaft, can you use a coupling?
john44
Re: Connecting the propeller shaft to the motor
« Reply #1 on: July 24, 2011, 01:46:09 pm »
Yes you have to use a coupling device of some sort. It depends in what type/size/speed of the motor, and what it is going
to drive. It may need a gearbox etc.
john
n33h
« Reply #2 on: July 24, 2011, 05:11:06 pm »
please give us more info, we need to know
what motor your using ??
what shaft are you using (solid metal shaft or flexible shaft)
what size the prop shaft and motor shaft is ??
there are so many different couplers avaliable but i suppose the most obvious couplers are
straight connectors (Xmm hole one end and Xmm hole the other)
universal joints (UJ's) with brass/metal inserts, one size for one end and one size for the other joind by a plastic u joint
as mentioned above, there MAY be a gear needed but we won't know unless you can tell us
Page created in 0.545 seconds with 17 queries.
