Author Topic: how to make a boat turn  (Read 4274 times)
selvatico
« on: July 25, 2011, 03:54:56 pm »
Good afternoon
i have just updated a speed boat from an out of the box RTR model, the original receiver unit allowed steering by slowing one of then motors making the boat turn (on the hand controller the right stick moved left and right)
with the mods I've got a similar effect from a 2.4 GHz receiver and 2 speed controllers turning is now done again by reducing power on either the left or right stick, (both up to go forward one forward one back to turn).
after testing this new set up steering is not easy or smooth. my question to you how do i achieve a set up that turns like the ordinal wilt the thumb stick moving left and right
selvatico
Re: how to make a boat turn
« Reply #1 on: July 25, 2011, 03:58:41 pm »
oh i don't fancy using a rudder on this model  %%
treeboa
« Reply #2 on: July 25, 2011, 04:36:24 pm »
mixer will do it
selvatico
« Reply #3 on: July 25, 2011, 04:46:03 pm »
thanks 12 views and finally some one replied.
thanks
nhp651
« Reply #4 on: July 25, 2011, 04:55:02 pm »
thanks
give us all a chance matey.....arf of us are ol' fuddy duddies and need chance and time to think about these things and put our decayin' brains into gear before we shoot our mouths off. {-) {-) {-) {-) {-) {-) {-) {-)
selvatico
« Reply #5 on: July 25, 2011, 05:27:50 pm »
sorry no offence was ment,
I didt think this question was as hard as it it. After looking for mixers only 2 types come up in e bay one for RC plains and a home made one for a boat.
« Reply #6 on: July 25, 2011, 05:34:26 pm »
And searching google, rather than ebay, scrolling down the google hit list half a page, this -
http://www.action-electronics.co.uk/mixers.php
Fleabay is not the only source to look in, there are lots of alternatives.
barriew
« Reply #7 on: July 25, 2011, 06:22:14 pm »
.... and you may have mixing built in to your Transmitter. What is the model of your Tx? This is not quite as flexible as a separate mixer, but will work.
Barrie
selvatico
« Reply #8 on: July 25, 2011, 06:58:48 pm »
the transmitter and reciver are a saturn 2.4ghz FHSS rc system
http://www.galaxymodels.co.uk/detail.asp?id=29389&rootid=2%7C134%7C1029
n33h
« Reply #9 on: July 25, 2011, 07:08:47 pm »
you could have both esc's on one stick and use the 2nd stick to a servo which breaks the contact to either motor IE- move stick left breaks contact with the right motor, move stick right and breaks contact with the left motor
what you want to achieve is called vectored steering
nhp651
« Reply #10 on: July 25, 2011, 07:16:20 pm »
no offense taken, :-))
« Reply #11 on: July 25, 2011, 07:18:29 pm »
BTW: what boat is it?
 Mucking about with a RTR boats guts may not be as easy as we make it sound?
 Can you post photos please?
        PS. Where me fence gone? Someone's taken it!   :embarrassed:
selvatico
« Reply #12 on: July 25, 2011, 08:33:12 pm »
barriew
« Reply #13 on: July 25, 2011, 08:35:39 pm »
The spec doesn't mention mixing - surprising for an aircraft RC system. So, either a servo controlled switch or a mixer.
Barrie
philk
« Reply #14 on: July 25, 2011, 09:03:21 pm »
funny enough i've been playing with one of those. put a 17 turn double in it and a rudder. not on the water yet hopefully next weekend
phil
« Reply #15 on: July 25, 2011, 09:43:55 pm »
That looks like 2 x ESC is that correct?
 The photos are a bit small, could you repost at 800 x 600...* click family safe! *
n33h
« Reply #16 on: July 26, 2011, 08:29:59 am »
looks like a high wind NQD boat to me (the 1st boat i started with) and converted it to single jet drive
selvatico
« Reply #17 on: July 26, 2011, 09:14:09 am »
yes I'm currently running 2 20A ESC and 2 1550 rpm motors
each set is powered by one Li Po batt
(but one of the ESC got hot and smoked causing a wire in the motor to melt away, so after pay day I'm getting 2 100A ESC and 2 4800 rpm motors)
Philipsparker
« Reply #18 on: July 26, 2011, 01:00:52 pm »
I've seen one of these with a single motor & rudder - looked like it was working well. It's certainly what I plan to do with mine at some point.
Phil
selvatico
« Reply #19 on: July 27, 2011, 11:18:27 am »
Thank you for your help, i have been shown this little device that seems to do what i need. will up date when it arrives and is fitted.
again thank you for all the ideas and comments
http://valley-electronics.co.uk/index.php?productID=985
