Author Topic: Cyclone conversion - help the newbie  (Read 3566 times)
Model Mick
« on: August 09, 2011, 11:53:26 am »
I have a speed x cyclone as a bit of a fun boat for me and the kids. Problem is its all or nothing and no reverse/brakes. this is it http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130541817051&ssPageName=STRK:MEWNX:IT#ht_1351wt_905
Can someone please tell what it will take to ad a speed controller and "proper" receiver. It has two motors and steers by slowing one, if you know what I mean.
If it had 1 motor and a rudder I think I could manage, but 2 motors and no rudder is out of my depth. do i need 2 esc's? do i need something to control each motor for turning??
Mick
Re: Cyclone conversion - help the newbie
« Reply #1 on: August 09, 2011, 12:06:48 pm »
Hi Mick
Yes you are going to need a better control system. It's certainly a nice large boat but, at £55 you will probably spend more on upgrading it to twin Speed controls and reverse features.  then there is the radio receiver to consider.
I notice the advert says  'reverse'  but the demo film did not show her going in this direction !!  Can you post a picture of the innards please.
Ken
Model Mick
« Reply #2 on: August 09, 2011, 12:16:59 pm »
Nope no reverse, also didn't say it would arrive with decals fitted by a blind man  {:-{
I know it will cost more, I intend on eventually going brushless etc...
This pic ok?? That's not the original battery
Hi Mick
Ken
« Reply #3 on: August 09, 2011, 02:25:33 pm »
Thank you for the picture.  You seem to have some room for upgrades, so best of luck.
Ken
Model Mick
« Reply #4 on: August 09, 2011, 04:24:13 pm »
Ken
awwww you not gonna tell me how to do it?? lol
« Reply #5 on: August 09, 2011, 07:31:18 pm »
If you like  -----------------
First of all, rip out the radio (if there is No reverse system) and the speed controllers. Then get yourself a P94 dual controller from ACTion Electronics and a receiver of your choice. Not forgetting to fuse the system. This will enable you to drive the boat without rudders, forwards, backwards, in a tight circle in either direction. If you look on his site you will find drawings of how it's done.
If you're on a budget then two cheap ESC's should do it with a reversing radio and receiver but if you're thinking of going brushless then it's another mass purchase of matching equipment.
It does look an expensive conversion but at least you have a nice boat to do it with.
ken
Model Mick
« Reply #6 on: August 09, 2011, 09:18:45 pm »
Cheers fella
Its just a little project to keep me busy away from the waters edge ;)
Model Mick
« Reply #7 on: August 09, 2011, 09:21:17 pm »
Just out of curiousity, would it be cheaper and easier to convert to a single brushless motor/prop and ad a servo and rudder?? possible??
MikeA
« Reply #8 on: August 09, 2011, 09:58:01 pm »
no its not cheaper youl need a new radio aswell servos. get the 2.4ghz rc we was talking about then, get a servo and rudder off ebay. or make a rudder. do an amp test on if you can and run both motors off one speed controller.
Model Mick
« Reply #9 on: August 09, 2011, 10:03:25 pm »
Will a rudder work with 2 motors, or will i need dual rudders?
scalloway41
« Reply #10 on: August 09, 2011, 10:17:06 pm »
hello, dont mean to hyjack your thread but i have a very similar boat but with a ic motor in it and was looking for advice on what would be the best motor/esc/ battery set up to replace the ic to electric. mine has only one shaft and would like to achieve similar speed/performance and a decent run time if possible. cheers
MikeA
« Reply #11 on: August 09, 2011, 10:28:58 pm »
mick you just need one rudder in the centre. you need a rudder like this:
I have sent you a pm. check top left of page in user info if you dont know pms
