Author Topic: RC Ferrari Hydroplane ready to conversion, " some thing different"  (Read 17752 times)
MikeA
Re: RC Ferrari Hydroplane ready to conversion, " some thing different"
« Reply #25 on: September 04, 2011, 02:49:36 pm »
with lipos i gather that there charged voltage is higher than the pack states. if you have 2 2s batteries and there the same ah rating a c rating then run them in series and get 4s.
MikeA
« Reply #26 on: September 04, 2011, 02:59:33 pm »
did you manage to bend ya head round those destructions i sent you then. if youe running lipo set it to the right cell number dont use the auto calculate. its its 2s set it to 2 cell. leave the auto cut off at 3.2v if using lipos too
Meyer
« Reply #27 on: September 04, 2011, 04:06:52 pm »
Hi Mike,
thanks that, runnig on 2 x 2 cells, not tried the set up yet, thanks
cheers for now, Roy
Meyer
« Reply #28 on: September 04, 2011, 04:24:57 pm »
Well its a slow leaning curve, !!! just sorted out the Li-Po's "now at the correct v,
but My head is spinning, !!!! just cannot get the hang of those, Beeps,, and music tones,,,  I think I've had every combo possible accept no reverse, !!! "Must be getting old, !!!!
I get the music, and wait for that 1st beep (let go of the stick) now I'm confussed, !!! need a pint,
Cheers  Roy
MikeA
« Reply #29 on: September 04, 2011, 04:37:25 pm »
lol took me nearly 2 hours to get use to them beeps. right so you get the beeps and youve heard the first loop and after the first beep youve let go. now it should go beep then beep beep. after beep beep press forward again then let go.
if your using 2 X 2s then make sure they the same type same mah and c rating. And set your esc to 4 cell in your running them in series. 2 cell if your paralell
martno1fan
« Reply #30 on: September 04, 2011, 05:33:23 pm »
Hi, I have a RC Ferrari Hydroplane (built to a high std) coming from the States, I am going to convert to brushless watercooled, 3600kv & 60 a I'm going to upgrade the running gear and rudder & scoop,
any ideas or info would be most helpful and appreciate  to assist me on this build. ideas to make this a stable racer would be great,
length is 32 inches  10 inches high beam 14 inches weight approx 10/12 lbs
It says 10-12lb here ?,either way it will never be a racer,ive seen a scale dumas gas hydroplane run and it wasnt good it just wouldnt turn for anything and the guy couldnt belive how fast my zippkits went round the lake without backing off the throttle lol.If you just want to get it running thats fine but just dont expect too much.
Mart
MikeA
« Reply #31 on: September 04, 2011, 05:52:33 pm »
no it wont be a missle but it could be scale speed
Meyer
« Reply #32 on: September 04, 2011, 07:38:51 pm »
Thanks for that Mike, (I thnk I've got it) much thanks,
I have just re-weighted the Hydro and mine is actual at 6.5 lbs dead on, !!! I do know other makers weigh in at 10/14 lbs, any how, so long as I get a decent speed, that will be fine by me,
martno1fan
« Reply #33 on: September 06, 2011, 11:54:14 am »
Scale speed would probs be arround 15 mph which to me would be a little slow.6.5 lb is still quite heavy,my 40" cig only weighs 4 lb bang on.You are going to need quite a bit of power to get it moving well.
Mart
MikeA
« Reply #34 on: September 06, 2011, 12:19:50 pm »
what motor are you going to run then that 1200kv? 3600 wont cut it with this.
Meyer
« Reply #35 on: September 06, 2011, 12:30:22 pm »
Hi Mike,
I'm not sure yet, I have a Feigao 2886 kv to try ?  " it all a learning curve ,so I'll have some fun with it, !!! thanks again,
roy
martno1fan
« Reply #36 on: September 06, 2011, 02:25:52 pm »
Big outrunner on two 3 s packs giving 6s should get it moving.Those little motors with high kv wont move it,get  at least a 125 amp esc.
Mart
http://www.himodel.com/electric/HiModel_PRO_Series_1970KV_Outrunner_Brushless_Motor_for_550-600_Helicopter_Type_HG3736-2T.html
Meyer
« Reply #37 on: September 06, 2011, 03:04:08 pm »
Hi Mart,
thanks for the link,
roy
Meyer
« Reply #38 on: September 22, 2011, 06:57:57 pm »
Hi, well starting to get parts together for this build,, had a word with Paul at Mtroniks, and he advised that my q1200kv and his speed controller G250A, would work fine for this build,
IN the pic ( is my spare canopy) its for sale , if anyone wants to buy it ? cheers
MikeA
« Reply #39 on: September 22, 2011, 07:10:46 pm »
you made a different one or something?
Meyer
« Reply #40 on: September 22, 2011, 07:51:58 pm »
 this is  an extra one I got shipped in, as I was going to do my own build,  , as I don't need it, its up for sale, cheers
fastrails
« Reply #41 on: March 15, 2013, 03:52:04 pm »
Hi, was this project ever completed?
Page created in 0.012 seconds with 18 queries.
