Author Topic: RNLI Severn boat 27 Mhz  (Read 3766 times)
johnboscoirl
« on: August 18, 2011, 09:32:22 pm »
HI! everyone newbie to ships/boat, but some experience with r/c planes. Recently purchased the above used and tested model through ebay, unfortunately paid over the top for what i though was a full function model.  Having briefly dry tested it appears that there is no rudder control and all i get are the two props turning. Have i completely missed something or is this the case.  If so then i guess model will require modification and a rudder system installed. Information on the supplied transmitter says "full function radio control".  I know it is "buyer beware" but i guess it isnt unreasonable to be able to steer a r/c boat. At the point of seeming really foolish, have i missed something really obvious.  Any ideas would be greatly appreciated.
Many thanks
Re: RNLI Severn boat 27 Mhz
« Reply #1 on: August 18, 2011, 09:39:27 pm »
Have you looked inside the model ? Check for a rudder servo.
If there isn't one then maybe it's controlled by independent propellers control.
johnboscoirl
« Reply #2 on: August 18, 2011, 09:49:38 pm »
thanks Ken, just looked at the two prop shafts. they are housed in what looks like an azipod structure, but they are fixed. There are no actual rudders on the boat, so you can see my dilemma, thanks for coming back to me
« Reply #3 on: August 18, 2011, 09:52:13 pm »
Steering by speeding up one prop and slowing down the other springs to mind.
johnboscoirl
« Reply #4 on: August 18, 2011, 10:01:19 pm »
thanks Richard, just checked out, both props work together, no independant control. Ill keep searching, many thanks
Number 6
« Reply #5 on: August 18, 2011, 10:10:51 pm »
I'm sure those ready to run RNLI Severn's work on kind of 'tank steering'. They aren't fitted with a rudder, that I do know. Should work if sold as running though?? Sorry I can't be of more help, Dave.  {:-{
« Reply #6 on: August 18, 2011, 10:11:26 pm »
It might have a mixer which means you would have one control for throttle and another control for turning.
This would alter the speed of each prop when the turn control is used along with the throttle one. :-))
mikearace
« Reply #7 on: August 18, 2011, 10:13:55 pm »
The RNLI RTR models are rudderless and steer by 'tank' steering as Number 6 has suggested.
john s 2
« Reply #8 on: August 18, 2011, 10:43:58 pm »
If its as i belive the Rnli boat then its basic control by either stopping or reversing motors.as needed.At least thats how mine works.If all else fails you could convert to one or two internal motors driving props and fit a rudder. Good luck. John.
johnboscoirl
« Reply #9 on: August 18, 2011, 11:38:03 pm »
thanks everyone for your help, looks like a conversion on the books
bikerdude666
« Reply #10 on: August 19, 2011, 08:29:12 am »
Is it the baby Severn? With White motor pods? It steers by reversing 1 motor like a tank.
Have a look at going for a jet drive conversion. Not got any videos at the moment but it's really good, should be taking it down the lake this weekend so will try and get a video!
« Reply #11 on: August 19, 2011, 09:16:50 am »
This one?
 ( do a search from the home page for  Baby Severn  )
http://www.modelboatmayhem.co.uk/forum/index.php?topic=1879.msg234213#msg234213
jim w
« Reply #12 on: August 23, 2011, 08:34:51 am »
My son has one of these. Very prone to seizing up motors when put away for periods of storage, so a precautionary drop of wd40 helps. I am just about to try a conversion to rudder and single prop.
They are a lovely little model and were readily available at around £45 a while ago, I was amazed at what they fetch now .....i saw one on eBay and the guy wanted £150 buy it now! Thankfully didnt look like it sold!
johnboscoirl
« Reply #13 on: August 23, 2011, 06:14:38 pm »
Thanks Jim, forum gave me the answers i needed, will probably still do a conversion.  Have another model arriving soon for parts or conversion, so will use it as my learning model. Thanks for the note re lubrication. :-)
Page created in 0.181 seconds with 18 queries.
