Pages: 1 2 3 [4] 5 6 7 8   Go Down
Author Topic: 1/96 Supertanker and more...  (Read 60413 times)
6705russell
Re: 1/96 Supertanker and more...
« Reply #75 on: April 09, 2012, 08:43:53 pm »
Hi John
Yes I have a big Jeep and with all seats down it will slide in no problem....
Russ
Number 6
« Reply #76 on: April 10, 2012, 07:22:53 am »
Failing that it'll fit in my car. The roof box I'll be making for Prinz Eugen will also fit the tanker with 2ft to spare.
Dave.  :-))
john44
« Reply #77 on: April 11, 2012, 10:07:45 am »
Food bowls as gas containers.( just an excuse to order meals from the takeaway)
Your secret is safe with us Russ. O0 {-) {-)
john
john44
« Reply #78 on: April 11, 2012, 10:16:50 am »
Dave.  :-))
Hi Dave, you could use the roof box lid as a loading/offloading ramp.You just need a little motorised winch
on top to drag them back in the box. O0 {-) {-)
john
6705russell
« Reply #79 on: April 11, 2012, 10:32:23 am »
john
 {-)  Actually John the more I look at them the  more I think they are to small...... Back to the drawing board on that one.
Russ
offshore1987
  • Good to be back
« Reply #80 on: May 26, 2012, 01:44:51 pm »
She finished yet?  :-)
Daniel
6705russell
« Reply #81 on: May 28, 2012, 08:16:03 pm »
Hi Dan
Unfortunately Dan I have only added some decals from Barrys Model Lettering, still on the lookout for some bigger food bowls to make the gas vessels....
Russ
offshore1987
  • Good to be back
« Reply #82 on: May 28, 2012, 09:46:30 pm »
Fine lookin model  :-))
She looks very nice as shes is though, has she seen water yet?
Daniel
deadwood
« Reply #83 on: May 30, 2012, 08:33:31 am »
Your takeaway food bowl halves' usage as gas calottes is a brilliant idea.
However, could you get them in a size with a wee bit wider diameter?
I think on a tanker one wouldn't waste that much extra space around the tanks.
Virtually, a tanker's hull is faired around the tanks after they have been arranged in a way that makes fullest use of the available space (i.e. displacement).
That's why the waterlines of ULCCs exhibit unfavourably high curvatures and buttocks with steep angles in the run (stern) which cause considerable headaches to the ship hydrodynamisists when designing an efficient propulsion.
« Reply #84 on: May 30, 2012, 08:53:40 am »
That quote alone has given me the most seering of considerable  headaches!! %% %% %%
could you explain in simple modellers terms please, as I for one haven't got a clue as to what you are on about {:-{ {:-{ {:-{
Looking very nice by the way, Russ...........haven't seen one built since I made the plugs, some years ago.
neil.
nick_75au
    • Logan City Marine Modellers
« Reply #85 on: May 30, 2012, 09:22:12 am »
I think he means tankers exhibit lines similar to a brick, so as to maximize the volume available to carry crude ;)
Of course the old dome style LNG tankers have been superseeded with membrane style tanks which can maximise volume of liquified gas
some interesting pics here of the new tankers the inside of a membrane tank ad a ship without a bow :o
http://www.flickriver.com/groups/lnglpgtankers/pool/interesting/
Nick
« Reply #86 on: May 30, 2012, 12:22:32 pm »
Nick
Cheers Nick......understand fully now......so much easier when you use none technical terms, {-) {-)
6705russell
« Reply #87 on: May 30, 2012, 12:44:25 pm »
Thanks lads,
If you look at reply no.79 I said I was on the lookout for some bigger bowls, still not found any yet though........ <:(
Russ
deadwood
« Reply #88 on: May 30, 2012, 01:12:36 pm »
Oh, I apologize for not having read through the whole thread carefully enough.
But your VLCC gas tanker will be an impressive model, no matter what size of bowls you will incorporate.
I think tankers and bulkers are seldom picked as a topic for model making and thus are a rare sight on model boat ponds.
Quite undeservedly, because they are an interesting type of ship, and some designs may even be considered to reveal a certain beauty,
like this more handy size gas carrier which I would fancy if I ever built a model of a crude carrier.
deadwood
« Reply #89 on: May 30, 2012, 01:28:31 pm »
Yes, exactly.
They have the highest block coefficients (which is the ratio of the volumetric displacement of the hull vs. the block that would be formed when multiplying its main dimensions, Lpp, B, T, and hence a measure of fulness) among sea-going vessels.
This makes them especially susceptible to flow separation and poor propeller inflow.
Thus much research has been devoted to the propulsion issues of single screw high block coefficient vessels (viz. in many ship model basins like e.g. MARIN)
Arrow5
« Reply #90 on: June 02, 2012, 06:11:25 pm »
Spotted these possiblities in Homebase. They are sold in three s. Might be lucky.
..well can you land on this?
6705russell
« Reply #91 on: June 03, 2012, 09:23:50 pm »
Thanks Arrow but with the assistance of Gribeauval in Asda last Friday Spotting some new plastic camping salad bowls I am now sorted....
Russ
offshore1987
  • Good to be back
« Reply #92 on: June 03, 2012, 09:43:36 pm »
Friday??? its now sunday evening wheres the pics of a finished model  :}
All the best
Daniel
6705russell
« Reply #93 on: June 04, 2012, 10:49:23 am »
The salad bowls, err I mean the bespoke gas vessels have been sprayed up but not sure if i like the colour or not yet?  i will start making the gantrys up this week....
Russ
offshore1987
  • Good to be back
« Reply #94 on: June 04, 2012, 04:20:33 pm »
Maybe im mad but a darkish yellow might look nice? ( though i do like the clean cut of the white ) Colour does look abit much sometimes
Daniel
6705russell
« Reply #95 on: June 04, 2012, 06:07:12 pm »
We must be on the same wavelength, as soon as I got back this afternoon i decided to spray a dull yellow....
Russ
Number 6
« Reply #96 on: June 04, 2012, 08:02:27 pm »
Looking good Russ, what's 'salad' ?
6705russell
« Reply #97 on: June 04, 2012, 08:20:24 pm »
 Something me and you should eat more of mate!   {-)
john44
« Reply #98 on: June 04, 2012, 11:32:16 pm »
Looking good Russ. Is that salad you had on your triple beef burger. {-)
john
offshore1987
  • Good to be back
« Reply #99 on: June 04, 2012, 11:56:06 pm »
Haha thats awesome spot on  :-)) Great minds and all
Shes looking rather nice sir
Daniel
Pages: 1 2 3 [4] 5 6 7 8   Go Up
Page created in 0.101 seconds with 22 queries.
