Author Topic: fast electric aerial position?  (Read 3903 times)
Patrick Henry
« on: August 24, 2011, 01:52:48 pm »
Chaps, am I ok with my aerial positioned as in the pic?
Radio is the GiantCod 2.4gHz installed in my Robbe Sea Jet...anybody forsee any problems?
Re: fast electric aerial position?
« Reply #1 on: August 24, 2011, 01:58:22 pm »
Yes 2.4 radio signal wont pass through water. O0
Is your antenna above the prop ? {:-{
What about boats wake, if it goes fast enough ? <:(
Patrick Henry
« Reply #2 on: August 24, 2011, 02:04:14 pm »
It'll go fast enough, fear not...it's just emptied the best part of a bath full of water in a split second!
I noticed that the fast electric, multi and offshore racing boys fit their aerials in similar positions...I can't put it anywhere else.
« Reply #3 on: August 24, 2011, 02:10:50 pm »
OK, just a thought. :-))
w3bby
« Reply #4 on: August 24, 2011, 02:56:54 pm »
Vertical through the top is my choice (if the aerial is long enough).
Patrick Henry
« Reply #5 on: August 24, 2011, 03:05:25 pm »
That may be awkward...I have a driver sat in the way!
« Reply #6 on: August 24, 2011, 03:20:11 pm »
I would have thought up near the handlebars, away for the motors, above the water, wake and other electrical gear...
 But to tell the truth, I would go try it out on the water... cautiously!
« Reply #7 on: August 24, 2011, 03:40:53 pm »
GC 2.4 rx velcroed under the deck with a horizontal aerial works perfectly all the way round the fountain in my Victoria in the pic
I would have thought it would be ok out of the back of the seat.
It will probably be out of sight before it is out of range
Patrick Henry
« Reply #8 on: August 24, 2011, 03:42:32 pm »
Ok..aerial now moved to a more upright position away from the rooster tail. This means practically all of the aerial is now outside the hull, up in the tube. The rx is mounted more or less directly under the aerial tube, where the old 40mHz one was.
I'll take your advice Martin...no more than two clicks of throttle until I'm happy!
Patrick Henry
« Reply #9 on: August 24, 2011, 03:43:47 pm »
Thanks Ned...it wouldn't have to go far to be out of my sight nowadays!
« Reply #10 on: August 24, 2011, 05:00:23 pm »
That boat in the background has sprung one hell of a leak!!!!
Patrick Henry
« Reply #11 on: August 24, 2011, 05:03:52 pm »
No Martin...that's JR's big Gato blowing ballast!
Nige52
« Reply #12 on: August 25, 2011, 07:51:39 am »
Rich, all of my boats are 2.4ghz, including my Robbe Jet Ski. The aerial is only a couple of inches long anyway, so I've found that as long as the receiver itself is above the waterline, there are no problems.  I don't have any aerial tubes whatsoever, the Rx just sits in the boat as would a normal Rx. I have GC 2.4 set-ups, Esky 2.4 set-ups and Planet 5 2.4 set-ups and have had no problem whatsoever with any of them...
Hope this helps
Nige  :-)) :-)
Patrick Henry
« Reply #13 on: August 25, 2011, 07:58:10 am »
Hi Nige,
My rx in the Sea Jet is way above the waterline, just underneath the seat at the stern.
Thanks mate...much appreciated.
Not a very good picture, but you can see where the rx is positioned.
RIch
dreadnought72
« Reply #14 on: August 25, 2011, 06:55:08 pm »
Nah - that's an experiment-gone-wrong with propshaft oiler tubes allowing water to magickally pump itself high into the air...  %%
Andy
