Pages: 1 2 [3]   Go Down
Author Topic: Royal navy BH7  (Read 29029 times)
Hover Tim
Re: Royal navy BH7
« Reply #50 on: June 03, 2012, 08:22:47 pm »
i think we are  :-)) designing a skirt is not easy have a look at http://www.rc-hovercraft.co.uk/infoframes.html click on downloads its heavy reading mind click on skirt calculator
unbuiltnautilus
Re: Royal navy BH7
« Reply #51 on: June 05, 2012, 02:34:50 pm »
Looking good, what colour scheme are you anticipating on using?
Hover Tim
Re: Royal navy BH7
« Reply #52 on: June 06, 2012, 08:01:51 pm »
this is the schems i have chosen http://www.flickr.com/photos/19759955@N07/6559838877/in/set-72157627625929657 but without such items like the life boat on the side
Hover Tim
Re: Royal navy BH7
« Reply #53 on: August 04, 2012, 09:35:55 pm »
its been a while but i managed to get back on the build i have done all the lats at last so next job i think is working puff ports that go on the front two each side these steal lift air and vent it from either side to push the front end left or right
TheLongBuild
  • Build em, and play hard..
Re: Royal navy BH7
« Reply #54 on: August 04, 2012, 09:38:01 pm »
Looking Good, You Going to the Boat Convention at Haydock ?.
Hover Tim
Re: Royal navy BH7
« Reply #55 on: August 04, 2012, 10:39:48 pm »
Yes i will be there with Kirklees model boat club with this model and a red Griffon 2000
Hover Tim
Re: Royal navy BH7
« Reply #56 on: October 06, 2012, 05:04:14 pm »
I am slowly getting on with the BH7  i Recently i have made the puff ports these pop out from the side decks to direct air left or right they are quite effective on the full size craft but i doubt they will do anything at model size they will be hinged later but i have used masking tape for now
Hover Tim
Re: Royal navy BH7
« Reply #57 on: December 20, 2012, 06:30:35 pm »
Puff ports work now and connected to a servo and work on the pylon has started
Hover Tim
link
« Reply #58 on: December 20, 2012, 06:31:29 pm »
i have not put a larger pic on my flicker page at http://www.flickr.com/photos/19759955@N07/8292133652/in/photostream
Hover Tim
Re: Royal navy BH7
« Reply #59 on: May 01, 2013, 05:04:35 pm »
Its been a while since my last post as I have been getting her ready for paint so lots of sanding and not very interesting to see but that's done now and I have started work on the rivet detail this will take a long time but will be worth it in the end the first pic is the last coat of sealer waiting to be sanded
Stan
Re: Royal navy BH7
« Reply #60 on: May 01, 2013, 05:11:30 pm »
Hi Tim. Looking good. Will be on our water this year? What about the paint job are you going to use spray cans? Finally what is the colour scheme applied on this vessel?
Stan. ;) ;)
Hover Tim
Re: Royal navy BH7
« Reply #61 on: May 01, 2013, 07:50:35 pm »
Cheers Stan
I am hoping to get it on the water this year but only time  will tell :-) , yep I will use Halfords spray paint for the model as for the colour scheme its
Hover Tim
Navy Hovercraft
« Reply #62 on: February 04, 2014, 08:13:14 pm »
Hello all
I did a build log for this model but its been a while since i updated and i cant seem to find it now.I am making good progress on the rivets still lots to do i think i am up to 3000 now each one pushed in or a hole drilled and pushed in,Both have been dipped in glue prior to been pushed in place
TheLongBuild
Re: Navy Hovercraft
« Reply #63 on: February 04, 2014, 08:17:25 pm »
Re: Royal navy BH7
« Reply #64 on: February 04, 2014, 08:39:37 pm »
Topics merged.
 Thanks TLB!  :-))
Hover Tim
Re: Royal navy BH7
« Reply #65 on: February 04, 2014, 08:47:56 pm »
Thanks Martin
McGherkin
Re: Royal navy BH7
« Reply #66 on: February 04, 2014, 08:53:58 pm »
Holy moly! The attention to detail with all that riveting is... riveting!  {-)
Such a good job, truly looking forward to seeing it up on the hover.
Hover Tim
Re: Royal navy BH7
« Reply #67 on: February 04, 2014, 09:49:53 pm »
Thanks,Yeah its rivets stuff its taken a long time to do them but i have the radio on in the workshop and i just seem to get on with them easily
Yeah i cant wait to see it hover too
Sub driver
Re: Royal navy BH7
« Reply #68 on: February 04, 2014, 09:50:10 pm »
Hi Tim.
I bet it will have put on a bit of weight with all that brass.  %% Worth all the effort in the end though nearly there.
Looking good, nice paint scheme too.
That and my two should look super together.
Regards sub.
Hover Tim
Re: Royal navy BH7
« Reply #69 on: February 05, 2014, 09:43:04 pm »
your two will put mine to shame Chris thats for sure
Hover Tim
Re: Royal navy BH7
« Reply #70 on: August 03, 2014, 11:23:55 am »
ITs been a while since i updated the build,I have been putting the skirt on which is not an easy job.the original lift air intake was not big enough so a temp on has been made while i do tests.there is also a problem in that the skirt attached under the hull  down the sides is too far inn and needs moving out a the fingers are getting squashed.but so far its promising
Pages: 1 2 [3]   Go Up
Page created in 0.727 seconds with 17 queries.
