Author Topic: Model slipway Yorkshireman  (Read 4189 times)
bobgrimward
« on: October 16, 2011, 01:34:04 pm »
Hi Gents,
I am building the Yorkshireman and I am just about to install the electrics. I intend to run two MFA 919D series motors at 6:1 gear ratio, my question is can I use two Mtroniks sport 20 ESC to drive the motors. As you can guess I am quite new to twin screwed boats in fact this is the first one.
Many thanks for your advice.
justboatonic
Re: Model slipway Yorkshireman
« Reply #1 on: October 16, 2011, 02:06:59 pm »
I'd have thought so. I presume the 20 in the name means the esc is rated to 20 amps and under normal use, those motors will only draw about 2.5 amps each.
oldiron
« Reply #2 on: October 16, 2011, 04:44:11 pm »
I'd go with the ACTION p94. Its gives phenomenal control to a twin prop vessel.
« Reply #3 on: October 16, 2011, 06:41:10 pm »
I'd also go with ACTion's  P94
Have done three times already.
http://www.action-electronics.co.uk/pdfs/Slipway%20Dutch%20Courage.pdf
irishcarguy
« Reply #4 on: October 17, 2011, 08:03:40 pm »
Hi Bob, I too would endorse the ACTion p94. Thats what I am using in my Smitty & Fairmount Alpine, You are buying one unit that does the job of three in your case. Mick B.
Mick B.
