Author Topic: WTC endcap query  (Read 7852 times)
bbdave
WTC endcap query
« on: November 13, 2011, 12:01:14 am »
I have been looking at the comercialy available resin end caps but looking at some pics online some folks don't seem to use any sort of retaining system for them e.g. threaded rod are they just held by friction? any manufacturer recomendations for end caps?.
My only experience is with bayonet rings and bolted down acrylic lid type unless i can get a 110mm bayonet ring.
andyn
Re: WTC endcap query
« Reply #1 on: November 13, 2011, 11:53:16 am »
You can drill them out to fit threaded bar, yes. In my experience, they can hold themselves on quite well.
Andy :-)
Subculture
    • Dive-in to Model submarines
« Reply #2 on: November 13, 2011, 12:13:19 pm »
Just don't use push fit end caps with a piston tank system- dive times will improve dramatically, but it will take a very long time to come back up!
andyn
« Reply #3 on: November 13, 2011, 12:45:27 pm »
 {-) very true
Sub driver
« Reply #4 on: November 13, 2011, 12:58:55 pm »
bbdave .
For Info.
Some systems use the air that is in the pressure hull to push the water out of the ballast tank via an air pump therefore creating a vacuum in the main pressure hull.
This vacuum holds the end caps on and there is no need for rods etc to secure them.
Not my idea of a belt and braces approach but it does work.
regards sub.
Subculture
« Reply #5 on: November 13, 2011, 01:53:31 pm »
I find that with a lot of extruded tubing the internal dimensions can be rather variable. Either out of round, lumps and bumps etc.
I find the larger the sizes are more prone to this, as the tolerance is generally a percentage of the tubing diameter.
It does depend on the manufacturer/supplier, some supply better stuff than others.
Perhaps it's for this reason that most of the ready made WTC's of larger diameter use axial compression of the seals instead of radial compression.
If radial compression is a must, a larger and more compliant o-ring may help, or simply doubling up of o-rings. Other solutions include machining a collar to be bonded in to the tube, or even machining out the tube itself, if you have lathe large enough and sufficient material to enable that course of action.
bbdave
« Reply #6 on: November 13, 2011, 03:46:26 pm »
I'm planning a snort system so no pressure inside i guess i'll put threaded bar in to satisfy concerns the O.D. isn't decided yet untill i have all the bits and see how small i can get away with.
It's all just pawing over plans and sketching at the moment i've got a Revel Mk 22 spitfire on the table at the mo so not much sub building this side of xmas.
bbdave
« Reply #7 on: April 29, 2012, 09:34:28 am »
Just looking back at this can some one let me know some end cap suppliers i did have the info in my messages bit since the crash all my info is gone so need to find it all again.
U-33
  • K-157 Vepr. Akula-11
« Reply #8 on: April 29, 2012, 10:29:51 am »
MMB (Marks Model Bits) down in Welsh Wales will cast you a set in resin...
Or Paul Holman (Turbulent on here) will make you a set in clear acrylic/lexan on the lathe.
If you decide to go for the lathe turned set from Paul, pm me for his phone number.
bbdave
« Reply #9 on: April 29, 2012, 01:32:51 pm »
I did look on MMBs but didn't see them so guessed they had stopped doing them i'll give them a call cheers
U-33
« Reply #10 on: April 29, 2012, 01:36:33 pm »
It's on the 'submarine' page, Dave...under the picture of that Sonic thing.
WTC caps and tanks
We will manufacture any size end cap up to 110mm tube diameter. Contact us with your specific requirements.
0 - 70mm tube - £10 a pair
70 - 110mm tube - £20 a pair
U-33
« Reply #11 on: April 29, 2012, 01:42:07 pm »
Fingers crossed you got the info that time mate...you're not the only one with site problems here, try loading a pic!
Subculture
« Reply #12 on: April 29, 2012, 05:55:14 pm »
U-33
« Reply #13 on: April 29, 2012, 05:56:26 pm »
Subculture
« Reply #14 on: April 29, 2012, 06:03:34 pm »
U-33
« Reply #15 on: April 29, 2012, 06:09:00 pm »
Dear, oh dear, oh dear...there always has to be one.
thegrimreaper
« Reply #16 on: April 30, 2012, 10:20:13 am »
Dear me Andy your looking very old and withered since the last dive in  {-) {-) {-)
Don't lie, thieve, cheat or steal. The Government do not like the competition.
