Author Topic: Drive belts  (Read 4322 times)
tobyker
Drive belts
« on: March 23, 2007, 12:12:23 pm »
Does anyone know a source for pulley drive belts? I saw some on paddleducks whch were round section and looked a bit like large O rings. The problem with these things is that you find something in the odds and ends box that just does the trick until it breaks and then you can't find a replacement. I don't want toothesd or flat belts as the pulleys are too expensive, and I'm looking for a quiet reduction drive - I was going to use a planetary gearbox and motor from a battery screwdriver but it really is too noisy, and with a wooden hull for a soundbox it will be even worse.
Daryl
Re: Drive belts
« Reply #1 on: March 23, 2007, 12:21:31 pm »
You could try HPC Gears www.hpcgears.com or Squires tel 01243 842525
Daryl
BobF
Re: Drive belts
« Reply #2 on: March 23, 2007, 01:36:23 pm »
Hi tobyker,
I use the seals from plastic waste water fittings. There are a few sizes available, and once you decide on the size you require, you just by a couple of spares. There was a thread a couple of weeks ago re o rings and quite a lot of sizes were available.
I've never had one break yet, and some are eight years old.
chingdevil
Re: Drive belts
« Reply #3 on: March 23, 2007, 01:48:47 pm »
Why not try a company like Brammer, they are the biggest supplier of drive belts and "o" rings in the UK to engineering companies. I am pretty sure if you go to one of their trade counters there is not a minimum order. They used to be called BSL.
The other Brian
rats
Re: Drive belts
« Reply #4 on: March 23, 2007, 02:38:12 pm »
http://www.mobilemarinemodels.com/PDF/Running_Gear.pdf
    Mobile Marine Models do drive belts and pulleys
Re: Drive belts
« Reply #5 on: March 23, 2007, 08:59:02 pm »
O rings are OK but get the thinnest ones you can for the required diameter and try to keep the setup as circular as possible. The more you pull O rings out of their normal shape the more drag you get and it increases exponentially! I have often used double pulley arrangements with success, that way you can use thinner cross section belts as you have two of them taking the load. Using this method you can even get away with elastic bands if the model isn't too big.
norry
Re: Drive belts
« Reply #6 on: April 05, 2007, 07:59:32 pm »
...Hi Guys...
I was looking fot "O" Rings recently to use as drive belts for the winch on my tug...
The Chandlers at my local Marina was the best place for a good selection of "O" rings....
They had them in all shapes & sizes...Also you can buy a mixed pack at B & Q...
 I Hope this helps...All The Best...Norry...
Page created in 0.028 seconds with 18 queries.
