Glad to hear it worked out mate,best way to balance the boat is not to add weight been there done that ,maybe a bit of down angle on the drive will help but first try angling the rudder in towards the transom a tad that will bring the nose down a bit depending on how bad it is i guess.Maybe moving the fuel tank forward would be best idea rather than adding any more weight?.but def try the rudder thing.
Mart
Mart,
If by angling the rudder in, you mean the tip of the rudder further forward than the top of the rudder, I think you've got it the wrong way round.
The rudder, and anything else touching the water at the transom end will tend to lift the transom, and therefore bring the nose down. Angling the tip (bottom / submerged end) of the rudder in (nearer the transom) will tend to direct some of the water flow up the rudder, and reduce the lift from the rudder, therefore raising the nose. This will be most pronounced in turns, but should have a similar but lesser effect with a straight rudder (assuming that the front to rear cross section of the rudder is wedge shaped). Angling the rudder the other way (tip further back than the top) will produce more lift from the rudder - therefore raising the transom more, and pushing the nose down. Again, this will be more pronounced in turns, so angling the rudder outwards to lower the nose is likely to result in "bow steering", and spinouts.
As regards balance point, my opinion (mostly gut instinct) is that this should be positioned so that the boat flies at the right attitude when it comes off a wave, and lands at the right attitude. For a deep vee, surface driven, this should be slightly nose up. If this is right, but it porpoises, I would try and adjust it out with driveline adjustments or trimtabs. If it flies wrong, adjust that first, then trim the driveline etc. If it flies wrong, it will be horrible in the rough (personal experience there). It's quite hard to test without rough water though.....
Still working on getting my new AA boat to handle, but having trouble getting enough time on the water without breaking anything.
