Author Topic: Source for mahogany cladding for boiler and other boiler covering questions  (Read 3563 times)
Muleears
Merry Christmas to all you Mayhemmers!
I'm looking for a source for the mahogany strips that are used to cover boilers.  I have a source for the brass bands, just looking for the strips.  Also, do you attach them to the boiler other than with the bands?  Do you leave them raw or do you finish them with urethane or varnish?  I have some ceramic cloth insulation that I want to wrap the boiler with, should the strips be attached to that somehow or just hold everything together with the bands?  TIA
Merry Christmas
redpiperbob
Hi Muieers
The last boiler I cladded I wrapped the insulating material around the boiler then held it in place with thin fuse wire then did the same with the planks then instant glued the edge of the planks then used polyurethane varnish and then fitted the straps .
All the best
PS I get my wood from these people. But I dont know if they ship to USA.
http://balsacabin.webs.com/othermahogany.html
Muleears
Thank you Bob, I was able to find some mahogany strips at model expo.  They are 5/64 X 15/64 and approx. 20" long.  I believe that translates to 2mm X 6mm.  I hope that is an appropriate size for lagging my boiler and condenser.
Thank you Logoman, that is a great tutorial on lagging a boiler.  I have a question though.  When you are finished is there a layer of tape between the lagging and the insulation?  I may not follow how you hold the lagging strips together while attaching to the boiler if the outer layer of tape has been removed.  Thanks
logoman
yes, there is a layer of tape holding the lagging to the insulation.
Page created in 0.014 seconds with 15 queries.
