Author Topic: My new Planet T5 Radio  (Read 8175 times)
TailUK
« on: January 25, 2012, 04:12:31 pm »
I've just received my brand new Planet T5 radio control complete with receiver.  Does anyone know what type of plugs fit onto the receiver.  I think they are Futaba but I don't want to buy the wrong type, also are there any types of ESCs or servos I should avoid with this rig?
Re: My new Planet T5 Radio
« Reply #1 on: January 25, 2012, 04:30:43 pm »
Any of the 3pin sockets will fit, just make sure yo put them on the right way round as shewn in the instructions.
Any servos or ESC should be fine.
portside II
  • tugs at rest
« Reply #2 on: January 25, 2012, 08:56:49 pm »
Yep as above, If your plug has a tab on it you may have to remove it with a sharp knife (be carefull of your fingers )
and make sure you dont cut into the plug wire .
daz
« Reply #3 on: February 05, 2012, 03:50:32 am »
You dont need to alter the plug to fit the Planet 5 receiver.  :-))
murphy1570
« Reply #4 on: February 08, 2012, 12:32:22 am »
Hello folks
I to have a planet T5 radio and having read the responses above I would be grateful if any member could advise me re the following, does anyone have experience of using an MTRONICS ESC with bec with the planet 5, and have they experienced any problems, also if I put the esc plug the wrong way round into the reciever will I damage the esc or the reciever? any advice would be appreciated before I do some teminal damage to the equipment!!
« Reply #5 on: February 08, 2012, 07:07:30 am »
Hi Murphy this might help
Instruction book page 5    Rx Channel Assignment:
                                     1 - Throttle
                                     2 - Rudder
Your rudder might work on one of the other channels
Plug your esc in with the exposed gold pins facing to the right and the  brown / black cable adjacent to rear of Rx
Instruction book   http://www.jperkinsdistribution.co.uk/downloads/7710150c.pdf
TailUK
« Reply #6 on: February 08, 2012, 11:58:33 am »
I've just got my Mtroniks Viper Marine 15 and I'm confused too.  The Planet R6M receiver has 7 sets of pins reading "B" and "1 -6" from left to right as you look at the Rx from the pin end. If I'm using the BEC do I connect the ESC to the "B" position? I know that using a separate Rx battery I'd have to disconnect the red wire from the ESC
The ESC has 3 wires; orange/red/brown  I assume red is positive, orange is signal and brown is negative, so the orange has to go at to top or upper face of the Rx.
The servo needs to fit on the appropriate set of pins but which would correspond to the right stick on the control box?  I assume that if I tried each in turn until I got a response from the servo I could find the right one by process of elimination or would this hurt the RX or Servo?
A lot of questions I'm afraid, but at 20.00 quid a pop I don't need the ESC to go pop.
« Reply #7 on: February 08, 2012, 01:10:13 pm »
Same as above
Battery to B if using separate batteries and disconnect red wire.
Connect Esc to 1 if using BEC
Servo to 2
Brown or black cables adjacent to rear face of receiver with exposed gold pins facing the right.
john44
« Reply #8 on: February 08, 2012, 01:15:26 pm »
Hi TailUK,The ESC connects to No 1 channel not ( B ) when using the BEC facility. ( do NOT connect your battery to B )
The chanel to stick positions are 1 & 4 left stick, 2 & 3 right stick.
There is a do not put in bin sign on the left side of the Rx case with a thick black line under it,
The negative lead always aligns with the black line. or bottom pin.
john
TailUK
« Reply #9 on: February 08, 2012, 01:20:08 pm »
That's great, exactly what I needed to know, thanks.  :-))
« Reply #10 on: February 08, 2012, 03:00:51 pm »
john
Exactly what I'd already said.  :-))
TailUK
« Reply #11 on: February 08, 2012, 05:40:41 pm »
So with a couple of small modifications here's the set up on the bench.  I substituted the bullet connecters from the Viper with a Tamiya female socket and put a male connector on the motor lead.  I used a female on the motor leads to prevent accidental connection to the battery lead which has a male connector.  A small piece of tape is put on the motor shaft to show it's running and the whole thing plugged in.
Fingers crossed I switched it all on.
http://youtu.be/KLFzBuMjepU
« Reply #12 on: February 08, 2012, 06:56:20 pm »
Luverly jubberly.
Wasn't that hard was it, well done.
TailUK
« Reply #13 on: February 09, 2012, 08:41:18 am »
Luverly jubberly.
To be honest I didn't think it would be difficult but I wanted to make sure I got it right. :-))
john44
« Reply #14 on: February 09, 2012, 02:05:58 pm »
  Well done, it is always better to ask if not sure,
the wealth of knowledge available on the forum is phenomenal
especially people like DickyD who has helped me on a few occasions.
john
Page created in 0.017 seconds with 16 queries.
