Author Topic: Mystery Motor  (Read 5459 times)
Mystery Motor
« on: February 09, 2012, 07:10:44 am »
http://www.modelboatmayhem.co.uk/forum/index.php?topic=35334.0
Any Ideas about the motor in the above link?
HS93 (RIP)
  • I cannot spell , tough
Re: Mystery Motor
« Reply #1 on: February 09, 2012, 07:19:04 am »
it's a Bühler Motor. most where 24v good 12 pole motors
it may have looked like this one
http://ctrsurplus.com/buhlermotor24voltdc3000rpm113018086new.aspx
Peter
Re: Mystery Motor
« Reply #2 on: February 09, 2012, 12:44:50 pm »
Slookin a bit like an ex car (Full size) motor, Fan/winder whineder type Ned. Slotted drive end casing suggests this as most of this duty requires good airflow.
Re: Mystery Motor
« Reply #3 on: February 09, 2012, 01:18:33 pm »
I thought it was automotive Ian and construction wise it looks like a Buhler Peter.
It runs on 1.5v,6v and 12V and 'sounds' right on 12v.
The thing is now, is it ok in my 1/16 Cygnus GM 38 with a 50mm four blade prop?
Re: Mystery Motor
« Reply #4 on: February 09, 2012, 01:25:34 pm »
Have you tried stalling it on load Ned? Can't be for a window app, exposed brush gear could set fire to upholstery if it sparked. Would think that there would be a manufacturers logo on it somewhere.
Re: Mystery Motor
« Reply #5 on: February 09, 2012, 01:55:31 pm »
It's quite torquey!
On 6V stall current is 12Amps
On 12V My meter shuts down as it's
only a 20A meter.
No load  6V  1A 12V  1.7A
No logos only 15  7  20 stamped on the casting at the brushgear end.
Also I have just realised after measuring I have not been sold a GM28 but a GM33 1/16  :embarrassed: :embarrassed:
grasshopper
    • A1 Hobbies Ltd.
Re: Mystery Motor
« Reply #6 on: February 09, 2012, 02:25:36 pm »
love it, needed a laugh on a lousy day -  thanks!  phonetic spelling is so cool.....window winder
HS93 (RIP)
Re: Mystery Motor
« Reply #8 on: February 09, 2012, 03:24:05 pm »
Think it might be a bit overpowered with one of those in a 2ft fishing boat.
They are deffo a bargain from that guy.
Re: Mystery Motor
« Reply #9 on: February 09, 2012, 04:43:30 pm »
   Ahhh Glasshopper, we need to be abel to get the jist over to all levels of understanding. Some of us rinklys carnt spull, some carnt reeed and unless there's a smattering of txt tork the faisbuk/twitter brigade have no chance.
  Back to the fray, didn't somebody mention a while ago about using Car heater motors for tugs as they were high torque? Looks substishiously like Pergeot/Citroen.
HS93 (RIP)
Re: Mystery Motor
« Reply #10 on: February 09, 2012, 07:07:12 pm »
I thought it was bigger, I was trying to match a motor to the prop, plenty of pulling power with the ebay motor just use 6v
Peter
knoby
Re: Mystery Motor
« Reply #11 on: February 09, 2012, 07:48:13 pm »
I think its a Ripmax Bullet 30. I believe they had a lot of poles, 24 is the number that comes to mind, but it may have been 12. They were a highly rated fast electric motor back in the mid 70's. I used to have 1 in a Nippy hull running on 18 cells. They were rated up to 24 volt.
Mind you I could be totally wrong, its many a moon since I last saw one.
Glenn
Re: Mystery Motor
« Reply #12 on: February 10, 2012, 03:48:37 pm »
Had some electronic correspondence with Deborah at Models by Design
and Andy reckons a 900 at 12V swinging a 55mm prop.
Spot on with the motor Peter  :-))
