Author Topic: flower arranging foam  (Read 2173 times)
manx venture
« on: March 04, 2012, 09:50:38 am »
i have used flower arranging foam to shape the hulls on my catemaran model, what would be the best filler to cover it over and smooth? its only a static model and will never be in the water
nhp651
Re: flower arranging foam
« Reply #1 on: March 04, 2012, 09:57:25 am »
it's also great for sticking your fittings into that have a locating pin on them..when you want to paint them. :-))
« Reply #2 on: March 04, 2012, 12:02:46 pm »
On a scale of 1 -Good to 10 - Abysmal, in constructional materials Manx Venture, you've picked 27 in using "Oasis". Even looking at it for too long causes dents in it and in not too long it deteriorates into dust. Not what you want to hear, but while you've still time, replace it with at least white expanded or better/best extruded foam.
   Regards    Ian.
Philipsparker
« Reply #3 on: March 04, 2012, 02:43:48 pm »
I'd experiment on a smapre lump with some fibreglass resin. If the foam doesn't melt when you apply the fibre sheet, then you could cover the Oasis nicely. If it does, well then you need a barrier filler, possibly Polyfiller and then fibreglass for a smooth top finish.
Big Ada
« Reply #4 on: March 04, 2012, 05:38:53 pm »
If its not going to get wet then Pollyfilla will do.
Len.
Page created in 0.016 seconds with 19 queries.
