October 27, 2025, 05:40:21 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Beginners start here...!
prop problem
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: prop problem (Read 1894 times)
morton
Guest
prop problem
on:
March 13, 2012, 08:06:27 pm »
hi ,i have a nylon prop which pushes on to the shaft,the prop has no thread and is a really tight fit,will i be able to buy a spare, is this normal for 1964 model, the shaft does not have a thread either.cheers.
cuppa
Guest
Re: prop problem
Reply #1 on:
March 13, 2012, 08:26:15 pm »
Hi Morton
you may be able to buy a replacement inner shaft with a standard size thread on to fit 'modern' props. Marks Model Bits are really helpful and make nice shafts for a very reasonable price it would be worth giving them a call because they can make a shaft to a length you specify :
http://marksmodelbits.com/
john s 2
Full Mayhemer
Offline
Southend on Sea Essex
Re: prop problem
Reply #2 on:
March 13, 2012, 08:55:43 pm »
It might be worth finding out what size your existing shaft is. One way if you dont have a micrometer is to use a drill shank, different sized ones till you find the size. If you mean that your boat is 1964 then its most likely to be imperial. It could be better to change the prop shaft complete.As said mmb can help you. John.
irishcarguy
Full Mayhemer
Offline
Happiness is running from a grizzly and escaping
Calgary N. W. Alberta, Canada
Re: prop problem
Reply #3 on:
March 13, 2012, 10:53:11 pm »
Hi Morton, you would be well advised to contact MMB, as Cuppa recommended, he makes very good shafts @ very reasonable prices & gives excellent service as well. It might be a good idea to discuss a new brass prop @ the same time to fit the new shaft if that is what he recommends, you will not go wrong with Mark's. Mick B.
Mick B.
Print
Pages: [
1
Go Up
« previous
next »
prop problem
