Author Topic: Simple feed flow indicator  (Read 2207 times)
flashtwo
« on: March 29, 2012, 08:57:08 am »
Hi Mayhemers,
On my steam boat "Vital Byte", I suspected that the feed pumps weren't performing up to scratch because of the non-return ball valves not fully seating.
On the suction side of the pumps I had a section of clear silicone tube, which on start-up would have a few bubbles of air in it. Briefly these bubbles would indicate a valve problem if they travelled backwards on the pumping stroke; they travel forwards on the suction stroke.
Very quickly the air bubbles would be drawn out of sight through the system and not be available for testing.
A simple solution was to prick the silicone tube with a large needle. Normally the hole produced would be sealed, but stretching the pipe would open up the hole and allow a bubble of air to enter under suction, releasing the pipe seals the hole.
Now I can check the pump valves at any time to ensure they are operating correctly.
HS93 (RIP)
  • I cannot spell , tough
Re: Simple feed flow indicator
« Reply #1 on: March 29, 2012, 06:58:08 pm »
are the the non-return ball valves  connected to something hot ? in that if it was a boiler, I know your system id different as soon as the water starts flowing the non return valve cools with the cold water , well they do on my Cheddar boiler's so temperature probe embedded in the nut  might give you the same information.
Peter
boneash
  • In an actual war zone there are 2 types of ships,
« Reply #2 on: March 29, 2012, 09:50:43 pm »
Brilliant bit of lateral thinking...
Well done
simpler than peristaltic injection
Page created in 0.306 seconds with 17 queries.
