Pages: 1 2 [3] 4 5 6 7   Go Down
Author Topic: Spearfish requirements...  (Read 46715 times)
U-33
  • K-157 Vepr. Akula-11
Re: Spearfish requirements...
« Reply #50 on: April 10, 2012, 06:08:22 pm »
Jon, just heard from my man...the Spearfish is on the way, depending on fast how the PO decide to operate, it should be here by Thursday. With a bit of luck and a following wind....
« Reply #51 on: April 10, 2012, 06:27:36 pm »
Sea-trials at the weekend then.
U-33
« Reply #52 on: April 10, 2012, 06:34:55 pm »
Hold on, Bob...got the decorating to finish first!
« Reply #53 on: April 10, 2012, 06:39:40 pm »
Oh Ok, so next weekend then  O0
U-33
« Reply #54 on: April 10, 2012, 06:52:44 pm »
Depends on how quick number one daughter waves the paintbrush about, Bob!
scoop
« Reply #55 on: April 12, 2012, 01:50:31 pm »
I had a Triumph! A 2.5 PI, P registered in dark green, with a set of fancy wheels on it.  I loved it, it was a real cracker of a car, built like a brick outhouse. The gearbox developed a fatal flaw internally which didn't do much for the rear axle....and so it had to go.
RIP, my 2.5PI
Anyone still looking for a Spearfish there's a s/h one on ebay at the moment, item number 130679472321  :-))
Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
U-33
« Reply #56 on: April 12, 2012, 03:06:46 pm »
Cheers Scoop...think I may pass on that one.
U-33
« Reply #57 on: April 14, 2012, 10:05:10 pm »
My Spearfish arrived today, so the slipway has been cleared ready. Couldn't resist opening the box, despite the decorating...
I've installed the propshaft and the rudder, watercooling inlet and outlet pipes are done, just waiting on the super new watercooled motor mount to arrive. Pics to follow tomorrow, but here's a couple showing the kit and the hull/deck.
U-33
« Reply #58 on: April 15, 2012, 08:47:26 am »
Couple more pics, just working out what will go where...
The motor is just laid temporarily in position just so as I can check the C of G.
« Reply #59 on: April 15, 2012, 09:14:32 am »
Any way you can get the motor a little bit further aft to shorten the unsupported shaft.
That coupling looks a bit suspect too.
U-33
« Reply #60 on: April 15, 2012, 09:22:25 am »
Fear not Bob, the new motor mount will take care of that....
Once that's fitted properly I can then trip the shaft down a bit. There's also a internal support which goes under the shaft to support it...belt n' braces.
(oh, and I've got a proper coupling to go in as well....)
« Reply #61 on: April 15, 2012, 11:24:29 am »
And if it is a true 550 (will take 12 volts) you can still have a mad moment connecting the batteries in series.
U-33
« Reply #62 on: April 15, 2012, 01:11:10 pm »
It's supposed to be a 600, Bob...I'm pretty sure that this is the motor I bought from Action for my MBD Biber sub last year (and never used)
The battery packs will be wired to give me 12v, so I think I'll have enough power without sacrificing run time...I hope.
triumphjon
« Reply #63 on: April 16, 2012, 08:27:13 am »
i see youve gone for the single shaft ? did you manage to find the shell, under spotted on the owners club site ? bit of a different veiw of them 1 no progress on either of mine for a few weeks , ive been either repairing the bits that have broken on my 4ft sailing fishing smack , or, been trying to sort my car prior to its pending mot test mid may ( im rectifiying years of neglect by its previous keepers )
U-33
« Reply #64 on: April 16, 2012, 08:42:35 am »
Yes, chose the single shaft road, Jon...I thought things would be easier that way.
That was an interesting pic of that shell, wasn't it? If he'd have parked that down this way, it wouldn't have been there long!
I'll add some more pics later, I've all but completed the battery/radio tray installation, shaft/rudder are installed, and whilst waiting for the glue to dry I've made a start on a representation of a dashboard.
ACTion
« Reply #65 on: April 16, 2012, 08:50:06 am »
Richard
Our 555 motors don't have cast backplates like that one, and a 555 wouldn't be anywhere near enough powerful to get a 36" model up on the plane. If it's one of the cheapo Johnson motors which you can buy for next to nothing - and it sure does look like one (see 'Bad 540 motors' here http://www.modelboatmayhem.co.uk/Common/Electrics/How%20Fast.htm#Fast%20motors) - then the ESC will last about half a second at full chat before it goes pop. Those things are all but lethal. You might get away with a P93 if you add much bigger heat-sinks to it (like P98) but in its standard form it's primarily for large sloggy motors which pull less than 10A continuous current..
DM
U-33
« Reply #66 on: April 16, 2012, 09:53:41 am »
I am now totally and utterly confused and confuddled.
The pic below shows three motors...the one in question, next to it a 380 for comparison, and a (supposedly) 550 as supplied by Hooben/Ark Model in their Perkasa kit. So which motor do I use?
U-33
« Reply #67 on: April 16, 2012, 06:03:59 pm »
Ok, I give up.
Thanks.
« Reply #68 on: April 16, 2012, 06:27:15 pm »
I would go for the Hooben one first.
These are quite high performance motors so you could try it on 6 volts first.
If not fast enough go to 12 volts.
Simples!!
triumphjon
« Reply #69 on: April 16, 2012, 07:12:46 pm »
the one on the left with its torque rings , or one from our local shop in portsmouth ( fratton models ) they have a good 600 low drain motor for  under a tenner , which is what we have been using in both my modified sea rover and standard crash tender ,
U-33
« Reply #70 on: April 16, 2012, 09:06:32 pm »
Right...confused no longer. The decision has been taken...and the choice is...wait for it...
The Hooben/Ark Model 550 motor. Both battery packs are wired in series..or is it parallel..whatever, I have 12volt @ 3700a/h to play with. I've fitted a 35mm 2 blade plastic prop to start with, and I can go up to 40mm or down to 30mm, whichever seems best.
I have the ACTion Multi Controller installed at the minute, but I've also ordered a Tornado esc from Howes...£30 for 50amps worth.
Bob...Jon...Dave @ ACTion...I thank you all for your contributions. If anything goes bang or catches fire or melts, I hereby absolve you all of any blame.
My grateful thanks, gentlemen...
triumphjon
« Reply #71 on: April 16, 2012, 10:20:26 pm »
not sure about the tornado esc , i know of somebody who bought one which caught fire the first time it was used !
U-33
« Reply #72 on: April 17, 2012, 08:26:17 am »
Oh sh.....ame!
Naff...
tattooed
« Reply #73 on: April 17, 2012, 12:43:13 pm »
Oh sh.....ame!
Naff...
thats very tame for you rich :-))
if it looks right and your happy with it then it is right
U-33
« Reply #74 on: April 17, 2012, 02:05:37 pm »
I've changed mate...I'm a true pillar of society nowadays, a man of the cloth.
Bless you, my son...
Pages: 1 2 [3] 4 5 6 7   Go Up
