Author Topic: Battery and motor  (Read 2028 times)
Dicky-P
Battery and motor
« on: July 04, 2012, 03:58:44 pm »
Could you please tell me if running a 7.2v motor on 8.4v batteries will cause damage to the motor
I have had my boat out once under these conditions and it got quite hot
Thank you
barriew
Re: Battery and motor
« Reply #1 on: July 04, 2012, 05:14:36 pm »
It will almost certainly shorten its life, but is unlikely to cause it to expire suddenly.
Barrie
« Reply #2 on: July 04, 2012, 05:26:03 pm »
Just keep an eye (finger) on the how hot the motor gets.
As a rule, it's too hot if wet finger sizzles on it!
scoop
« Reply #3 on: July 04, 2012, 05:51:33 pm »
Thank you
In the good old days I ran a Graupner 8.4v BB Turbo motor on 14.4v (2 x 7.2v Ni-Cads <remember those> in series) with a water cooling coil wrapped around the can, prop was an Octura around 45mm diameter, can't remember if it was a 4 or 6 series prop though.
It (the motor) never did get hot, mind you the batteries came in useful as hand warmers in brass monkey weather  :}
Your problem may be the loading on the motor, try a smaller diameter prop  O0
Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
Page created in 0.15 seconds with 18 queries.
