Author Topic: Electrolube epoxy resin  (Read 2355 times)
Steve
« on: August 12, 2012, 04:28:54 pm »
Hi I wondered if anyone had used Electrolube black epoxy for use as caulking, we use it at work for potting thermocouples and often wondered if anyone had used it before with success ? It's purchased From Farnell.
Steve
Steve
Re: Electrolube epoxy resin
« Reply #1 on: August 15, 2012, 08:04:35 pm »
This is how the product comes you remove the bar in the middle and the two parts mix together, it air dries around 20 degrees C.
And also here is the link for anyone interested.
http://uk.farnell.com/electrolube/er2002rp250g/encapsulant-epoxy-250g/dp/108779
« Reply #2 on: August 16, 2012, 09:15:21 am »
how would you get it in between the planks without staining the wood?
Steve
« Reply #3 on: August 16, 2012, 08:25:02 pm »
I would think if you used a syringe you could needle it in not entirely sure it will stain, I'm going to do some tests when I start my Huntsman,
You never know it could be the solution to the problem.
Steve.
« Reply #4 on: August 16, 2012, 09:32:04 pm »
Many years ago I used a similar system for gluing insulated rail joints together. We used to prepare the pack in warm water before mixing.
« Reply #5 on: August 17, 2012, 06:55:36 am »
Steve.
It would be interesting to see the results.
The syringe method could work but it would be slow going and my concern would be the resin starting to go off in the syringe
« Reply #6 on: August 17, 2012, 10:18:59 am »
Might work using the sharp card technique used in filling engraved panels with paint.
Page created in 0.145 seconds with 17 queries.
