Author Topic: What battery capacity do I need?  (Read 3440 times)
NFMike
« on: August 12, 2012, 11:25:17 pm »
For my first boat I'm building a Model Slipway Aziz. Twin screw (in case you didn't know) and using a pair of MFA 540 brushed motors with 6:1 gearing. I will be using 12V nominal for the electrics, probably with ACTion electronics, and having read all the debates about NiMH/NiCd, Lipo, etc, I think I'll stick with SLA for the battery(s).
But what sort of Ah capacity battery should I be looking for?
Obviously doing some bath tests would be ideal, but to do that I'd need a battery ....
So, as I'm sure plenty of others have built this or similar kits with these motors, I'm hoping to milk your collective brain for the information.
Peter Fitness
Re: What battery capacity do I need?
« Reply #1 on: August 12, 2012, 11:36:20 pm »
My answer to your question would be, the bigger the better. I haven't built an Aziz, but it seems to have quite a big hull which would allow you to fit a fairly big battery. It also seems likely that you would need ballast, so using a bigger battery would solve two problems - ballast to bring the boat down to its waterline, and running endurance. There are a number of members who have built Aziz, and they may have some ideas for you.
Peter.
john s 2
« Reply #2 on: August 13, 2012, 08:56:19 am »
A pair of 12v 7 amp hr batterys should be fine and help to cut down on Ballest. John.
NFMike
« Reply #3 on: August 13, 2012, 03:39:13 pm »
I have several kilos of lead flashing by my left elbow, so ballast is not a problem :)
So 14Ah is a likely figure? 7A per motor for one hour ... does that sound about right?
I don't really want to parallel connect high capacity batteries unless its essential - I feel its a path to problems.
« Reply #4 on: August 13, 2012, 04:35:37 pm »
Lead flashing does not run a motor
Just gives weight that has to be propelled through the water.
A bigger battery or two gives weight and thrust
NFMike
« Reply #5 on: August 13, 2012, 05:18:57 pm »
True. However, I'm unlikely to need more than an hour, maybe two, of running time at 'pootle' speeds. As I already have plenty of already paid for lead to hand there is no point in me spending extra money on excess battery capacity.
NFMike
« Reply #6 on: August 13, 2012, 05:34:10 pm »
I'll also need to source a battery and charger. I thought I saw a recommended supplier on here a little while back but of course I can't find it now.
Any recommendations, or avoids (subject to not being sued of course).
« Reply #7 on: August 13, 2012, 05:40:37 pm »
You wont go wrong with the guys at www.componentshop.co.uk
No bad words about these guys
Gazza
  • If its to windy to fly I'm boating
« Reply #8 on: May 26, 2013, 07:15:59 pm »
its all down to Mah  or Ah  the bigger the number the longer the run time
so a 2200mah Li-Po say lasts 20 minutes then a 4000 will last 40 minutes type of thing
so bigger is better in run time but longer on the charger
retired and loving it
