Author Topic: radar  (Read 3312 times)
rickles23
    • Royal Navy Commandos
radar
« on: August 22, 2012, 08:59:52 am »
As the group were helpful in locating the teardrop shaped navigation lights  for me could I ask where I might find a fully working radar unit?
Re: radar
« Reply #1 on: August 22, 2012, 09:04:27 am »
I stand to be corrected, rick, but I don't think there is anyone who actually does a working radar, as all the scanners are of different shapes.
I have a small geared motor I mounted in a box for use on a 1:32 scale trawler some years ago that I never used............you could have that with pleasure if you want..........it's then just a case of disguising the box and making a scanner.
neil.
Re: radar
« Reply #2 on: August 22, 2012, 09:51:47 am »
For a rotating radar, some people use a standard servo converted to continuous rotation ... and a a long extension shaft up through the superstructure.
F4TCT
  • I am not completely useless.......I can always serve as a BAD example
    • My Boat Builds
Re: radar
« Reply #3 on: August 22, 2012, 11:10:46 am »
I use a mini servo with continuous rotation connected to 1.5v battery which gives the perfect speed!
The bigger servos require 3v on continuous rotation i believe!
Dan
Stormbringer
Re: radar
« Reply #4 on: August 22, 2012, 12:35:07 pm »
ive used a micro helicopter servo on a single nihm (1.2v ) , i had to remove the little lug on the output gear and the 1/2 rounded part of the pot shaft to get it to rotate 360 degrees but it works great , also goes for over 26 hours on a 2000 mah cell
gwa84the2nd
Re: radar
« Reply #5 on: August 22, 2012, 04:16:36 pm »
NFMike
Re: radar
« Reply #6 on: August 23, 2012, 12:08:23 am »
I was thinking I'd animate the radar on my Aziz kit. Then I looked a bit harder at the mast :o
I like a challenge  O0
Umi_Ryuzuki
    • Models and Miniatures
Re: radar
« Reply #7 on: August 23, 2012, 12:21:07 am »
For the Aziz, it would have to be something like this...
http://video.google.com/videoplay?docid=-5063488244993245944
A connecting wire, or offset belt drive.
rickles23
Re: radar
« Reply #8 on: August 23, 2012, 09:55:28 am »
A good friend of mine has sent me this:
http://www.harbormodels.com/site08/radar.html
NFMike
Re: radar
« Reply #9 on: August 23, 2012, 12:39:28 pm »
Oooh! That IS interesting.
