Author Topic: Rudder Position  (Read 2708 times)
apennicardwood1
Rudder Position
« on: August 23, 2012, 07:08:57 am »
Hi All
I am looking at moving the rudder on my fast electric boat, at the moment it is off to one side of the hull and i was going to move it in line with the prop.
What i would like to know is why the rudder is put off to one side and if i move it will it help?
Thanks for any advice you can give.
Andy...
Re: Rudder Position
« Reply #1 on: August 23, 2012, 11:07:04 am »
The wake coming from any prop is actually corkscrewed, causing the boat to try and twist in the opposite direction, the rudder being
behind the prop on a 'fast electric' will exaggerate the effect increasing drag and reducing the boats turning ability. The rudder is therefore
offset, usually to the right to reduce this effect.
I think the idea is that there is so much water passing under a 'fast electric' that it doesn't really matter where the rudder actually is.
apennicardwood1
Re: Rudder Position
« Reply #2 on: August 23, 2012, 12:09:08 pm »
The rudder on my boat is set to the left of the prop and yes when it gets up and going it turns well, however i need a big space to get up to speed so at low speed i get almost no turn. To start with i don't think the rudder or servo was working as it powered away from me.
Would it be but then to put a twin rudder on to help at low speed?
Andy...
Re: Rudder Position
« Reply #3 on: August 23, 2012, 08:59:01 pm »
A second rudder might help at low speed, but then, you might never get the high speed.
I think some of the preference for the left mounted rudder was for left turn racing.
apennicardwood1
Re: Rudder Position
« Reply #4 on: August 23, 2012, 10:46:31 pm »
ok thanks for the advice i will have more of a play with this boat to see what will work best.
Thanks again for the advice.
Andy...
Page created in 0.82 seconds with 17 queries.
