Author Topic: Anyone know who owns this sub??  (Read 6567 times)
TomP
« on: August 31, 2012, 09:29:38 pm »
Seen this picture on the AMS Facebook page would really like to know if the front dive planes are functional? I have just drawn how I am going to do it now going to build them but would be good to see how others have done it. I'm hoping to use Pneumatics to raise and lower them. Cheers Tom
Re: Anyone know who owns this sub??
« Reply #1 on: August 31, 2012, 10:04:48 pm »
Tom,
Email bob he has drawings for working up planes, also I think there was drawings kicking about for operational
Otw o class.
Bob did say the space was tight for doing operational planes on the S
Subculture
    • Dive-in to Model submarines
« Reply #2 on: August 31, 2012, 10:40:13 pm »
I work with pneumatics quite a bit- difficult to make them operate in a controlled and subtle fashion- tend to be more bang-bang.
I would use hydraulics, which is quite straightforward as you can use syringes for master and slave cylinders, with a servo controlling the master cylinder. You can use vegetable oil as a fluid.
U-33
  • K-157 Vepr. Akula-11
« Reply #3 on: September 01, 2012, 08:56:23 am »
Tom, have a word with Paul Cook ('upscope' on here), I'm pretty certain that he has operational front planes on his Revell Gato. Failing that, have a sniff round either the Sub Committee or Sub Pirates websites, there's plenty of info on there about operational front planes on Revell Gato's which may give you give you some ideas.
And before I get jumped on, the ideas I've mentioned are of a mechanical ilk and not hydraulic or pneumatic, but you may gain some ideas.
Subculture
« Reply #4 on: September 01, 2012, 10:15:19 am »
How to get folding or retracting planes seems to be an often repeated request. There are several ways to skin the cat. Gato class boats are a very good reference, as they use the same methods, and more people build that class of boat, so more ideas floating about.
Here are a few pictures to get the ol' grey matter whirring.
« Reply #5 on: September 01, 2012, 10:53:00 am »
Could Always buy the engel gato unit,
But 250 euro's???
Sub driver
« Reply #6 on: September 01, 2012, 11:39:45 am »
batfish....i think the top pic is an engel unit.
Dave welsh also has a different method of moving the vanes on a revelle gato with a sliding mechanism.
Regards sub.
unbuiltnautilus
« Reply #7 on: September 01, 2012, 11:53:24 am »
This is one I squeezed into the front of an OTW Oberon, servo driven but might help a bit..
TomP
« Reply #8 on: September 01, 2012, 02:55:27 pm »
Hi thank you for all the replies. I have an Engel Gato retract system bought it off the German Ebay site for £35.
There is a big difference between the S class and the Gato, the Gato has an arm to lift and lower the plane where the S doesn't. I wanted to keep it as realistic as possible so don't want to put an arm in there like the Gato.
I have drawn how I am going to do it seems like it should work well just need to build it. The pneumatic cylinders I have are controlled by a variable rate manifold and works very well you can control how fast they fully retract.
I just wanted to see if this sub had fully working planes or not as there doesn't seem to be any arm controlling the plane would be interested to see how they work.
Subculture
« Reply #9 on: September 01, 2012, 03:52:40 pm »
The levers are probably run internally. In which case you can still use the same idea as in teh Gato, you just need to reorientate the mechanism. Not a big problem.
Meccano or techincal Lego are handy for figuring out these mechanisms and checkign to see they work well before you commit to materials. Failing that, a cardboard or plywood mock-up works well.
unseen
« Reply #10 on: September 01, 2012, 04:32:14 pm »
If this helps, this a photo of Otter breaking a few years ago which may give some idea how the forward planes work on a British Submarine
TomP
« Reply #11 on: September 01, 2012, 09:23:10 pm »
This is a roughly how I'm going to do it, the actual parts inside will work a bit like the Engel Typhoon but using the pneumatic cylinders
upscope
« Reply #12 on: September 03, 2012, 11:12:02 pm »
Here are some pictures of my folding bow planes on my 32nd Parallel Gato/Balao  the USS Lionfish.
These are driven simply by the Futabba 3305 mg servo, on the retract switch on my TX, using a servo slow does help the appearance on the water, rather than having them "flick" up and down.
Paul Cook
Norwich Model Boat Club
Association Of Model Submariners
unbuiltnautilus
« Reply #13 on: September 04, 2012, 12:21:55 pm »
Do they have a dive/surface function built in? If so, how does that side of it work?
upscope
« Reply #14 on: September 04, 2012, 04:19:03 pm »
Yes, there is. Its not alot of movement, about 1/4 imch up and down, it seems to be enough though. As you can see the effect at speed, although obvioulsy having a ballast tank she does not need them.
Paul
Paul Cook
Page created in 0.02 seconds with 18 queries.
