Author Topic: Programming ESC problem!  (Read 4363 times)
apennicardwood1
« on: September 04, 2012, 09:27:15 pm »
Hi all
I have just got all the parts that i needed for my boat (thanks to 'kinmel' for the receiver, last part i needed) now i am having a problem with setting up the ESC. At the moment the throttle is reversed but when i change it on the transmitter i get no change. I am using a Turnigy system (v2)
Can anyone help with this one?
Andy...
Re: Programming ESC problem!
« Reply #1 on: September 04, 2012, 10:24:51 pm »
Reverse the motor connections?
red181
« Reply #2 on: September 04, 2012, 11:02:59 pm »
if tx is a clone of turborix, flysky and similar, they are programmed on a pc, I think more info would help,. what esc, is it reversing, what specific tx is it?
thanks
apennicardwood1
« Reply #3 on: September 05, 2012, 07:13:34 am »
I am using a Turnigy 9x Tx with a Turnigy V2 Rx and the ESC is a Turbojet 100a water cooled, the Tx works fine with my helicopter.
Andy...
Chameo
« Reply #4 on: September 05, 2012, 11:39:18 am »
What do you mean by "throttle is reversed"? Does the motor only speed up when moving the stick from up to down position or does the motor turn the wrong way round? In first case reversing the channel on your TX should help, in the second case changing two of the three motor connections should work.
apennicardwood1
« Reply #6 on: September 05, 2012, 12:32:32 pm »
Yes thats the one.
Andy...
apennicardwood1
« Reply #7 on: September 05, 2012, 01:07:32 pm »
Some how I have got it to work not sure what I did, I put the TX back to normal settings and it worked fine.
Thanks for the help.
Andy...
« Reply #8 on: September 05, 2012, 01:16:56 pm »
Even though you've fixed yourself... we still charging you a call out fee!
   O0
apennicardwood1
« Reply #9 on: September 05, 2012, 02:13:35 pm »
Can I open a tab  :D
Andy...
apennicardwood1
« Reply #10 on: September 06, 2012, 07:05:05 am »
Hi all
For this motor http://www.fxmodelrc.com/Moteur-Brushless-500MX-1600KV-Align/ what would the best set up be on the ESC?
The settings that im unsure about are:
  Timing Mode Setting
1: For 2-4 pole inrunner motors
2: For 6-8 pole motors
3: For 10-14 pole outrunner motors
4: For 10-14 pole high-RPM outrunner motors
  Pulse Width Modulation (PWM) Setting
1: For low RPM and low pole count motors
2: For most out runner motors
Im going to set the other settings to 6s lipo, Auto Throttle Range, Soft Start, Soft Brake, Hard Cutoff.
Please let me know what you think.
Andy...
apennicardwood1
« Reply #11 on: September 07, 2012, 07:06:52 am »
Should I go for 10-14 pole outrunner or 10-14 pole high RPM outrunner?
The PWM im going to put as most outrunner motors.
Andy...
barriew
« Reply #12 on: September 07, 2012, 09:20:58 am »
Without details of your motor I don't think anyone ca answer that %)
Barrie
apennicardwood1
« Reply #13 on: September 07, 2012, 01:18:06 pm »
The link to the motor is in post 8.
Andy...
