Author Topic: Plastic glue  (Read 2451 times)
olly4950
Plastic glue
« on: September 25, 2012, 03:45:27 pm »
which is the best plastic card glue?
Many thanks
olly4950
Re: Plastic glue
« Reply #1 on: September 25, 2012, 03:57:13 pm »
For building in plasticard I just use liquid Plasweld, applied with a fine artists brush, it literally "welds" the pieces together in seconds. If I'm not happy with the result, simply dip the brush in the liquid and brush over the "weld" and take the joint apart. Then have another attempt till happy with the result.
The brush itself needs no cleaning. Just let it dry, there will be a bit of a coating on the bristles but this comes straight off when the brush is next dipped into the Plasweld.
....and at approx £2.50 a bottle it is excellent value for money.   :-))
KenP
Re: Plastic glue
« Reply #2 on: September 25, 2012, 04:25:32 pm »
Think I use the same stuff. Plastic Weld. Really great.  Got a very slow build of USS Missouri on a Fleetscale hull , and am using Styrene to build the superstructure and Plastic Weld to stick it all together.
Ken P
Re: Plastic glue
« Reply #3 on: September 25, 2012, 05:21:32 pm »
I use this which is the same as plasweld but a lot cheaper.
http://www.modelshop.co.uk/product/Liquid_solvent_cement_500ml_AM00003
Hope this helps.
Big Ada
Re: Plastic glue
« Reply #4 on: September 25, 2012, 06:33:46 pm »
And even cheaper and as good is, go to your local Plumbers Merchants and ask for a tin of Cleaner, NOT the solvent glue that is used to weld plastic waste pipes together.
Len, Ex Plumber, used to throw tins of this away as we never bothered to use it. If only I knew I was going to make Model Boats in the Future.
