Author Topic: Twin screw wiring help newbie  (Read 3501 times)
HKG3A3
« on: October 03, 2012, 10:03:31 pm »
Evening guys, i recently purchased a boat from a car boot sale which turned out to be one of those funfair pay your money and steer it type affairs.
Its built likt a tank, super thigh hull and the like. I t cam with a twin screw set up but no electrics.
Im just pondering on how to wire up the setup so one screw turns the wrong way. I have one speed controller and a 2 chanel reciever, i dont want to spend a lot.
Whats the best way to wite it up so i get clockwise and anti clockwise turneing?
I have a load of bullet clips and im guessing somewere alnong the line im gonna have to make a "y" section to get 4 wites into 2.
Many thanks guys, photos etc would be grear.
Re: Twin screw wiring help newbie
« Reply #1 on: October 04, 2012, 06:25:01 am »
Wire one motor the correct way [positive cable to positive terminal] then wire the other motor the wrong way [positive cable to negative terminal]
get a chocolate box connector and connect two red wires to one terminal and two black wires to another.
From the connector connect one red wire and one black wire and connect to the rest of your system
HKG3A3
« Reply #2 on: October 04, 2012, 08:04:29 am »
Agh brilliant, many thanks. That sounds nice and simple. Ill post some pictures up once ive done it.
Sorry to you and everyone for the spelling in the original post, i was trying to type it whilst my son was hitting the keyboard.
ATB
Adam
« Reply #3 on: October 04, 2012, 10:43:46 am »
Does it have a rudder?
TailUK
« Reply #4 on: October 04, 2012, 12:01:43 pm »
Is that a four funnel destroyer Dicky?  If it is I'd be interested to know what motors and props your'e using as it's on my build list.
HKG3A3
« Reply #5 on: October 04, 2012, 01:09:26 pm »
The original didnt, but i think im going to put one on. Smack between the screws at the back i thaught? It has 2 plastic fins pointing in on each other just behind the screws, shall i leave them on or dremmel them off?
« Reply #6 on: October 04, 2012, 02:44:38 pm »
Either 2 ESCs, one to control each prop separately, can be a handful on a 2 channel set unless a mixer is used, or hook both motors to 1 ESC (assuming its man enough to handle both) and fit a rudder and a servo to work it.  On a line between the props is OK, but astern of the props is more likely to work.  One rudder per prop is generally better, since the props deflect the propwash.
I didn't see whether the props were opposite handed, this needs Dicky's connection method to run on 1 ESC.
The 2 fins are probably there to act as fixed rudders, angled in they might help it steer straight on one motor, otherwise it would just go in circles is one motor conked out.  They might be a very good clue for where to site working rudders.
HKG3A3
« Reply #7 on: October 04, 2012, 09:22:15 pm »
Here we go guys, ive gone with the chocolate box set-up as recomended above. Works great, very pleased with myself. Just need a new battery as the one in the picture is about 15 years old at least and is on its last legs.
Good advice on the rudder i was thinking slightly off center.
john s 2
« Reply #8 on: October 05, 2012, 08:54:06 am »
You could buy, Money permitting buy one of Actions excellent P94 contorllers. Two escs and full mixing. You could spin your boat in its own length. John.
HKG3A3
« Reply #9 on: October 07, 2012, 11:13:02 am »
God this is turning into a project, total strip down now, motor mounts not up to the job, shaft need adjusting as new props are fowling, crack in the hull wall. LOL......still it could be raining.....(oh hang on)!!! :D
Page created in 0.229 seconds with 17 queries.
