Author Topic: Sanwa Dash Saber Manual  (Read 9154 times)
lakeshore
« on: October 17, 2012, 07:37:07 am »
Anyone got a scan of a Sanwa Dash Saber manual 27mhz am 2 channel.
John.
Re: Sanwa Dash Saber Manual
« Reply #1 on: October 17, 2012, 09:20:58 am »
As I recall, the "manual" was a piece of paper that basically said "Put 8 AA cells in this hole in the back, put your crystal in here, these are the sticks to work speed and direction".  For the receiver, you were told which channel was which and where to plug the RX battery in.  There was no mention of any peculiarity as to which pin was which, because it was assumed by the manufacturer that you would not be using any inferior, non-Sanwa products with it.
« Reply #2 on: October 17, 2012, 10:07:43 am »
yes, malcom that was the sum totam of it..i still have an old sanwa dash, but threw away the manual day I bought it as it told me nothing.
there's certainly nothing in it about ANY  technical stuff or how to replace gears, ratchets, quadrants etc.
neil
unbuiltnautilus
« Reply #3 on: October 17, 2012, 01:51:46 pm »
The Saber had manual dual rates on the steering stick, consisting of ( I think ) three position turn screws that restricted the stick from reaching full travel. Always rated the Saber as one of the nicest, ergonomically, of the two channel sets.
lakeshore
« Reply #4 on: October 17, 2012, 02:32:10 pm »
What I really wanted to do was use a Futaba S3003 servo for the rudder for my pusher tug and wanted the wireing diagram for the SRC-2322RS reciever pin outs.
John.
unbuiltnautilus
« Reply #5 on: October 17, 2012, 03:27:08 pm »
White being Signal.
Red being Positive.
Black being Negative.
The older Sanwa equipment had the black and red around the other way, and was the death of many servos! They changed their wiring over to match most other manufacturers quite a few years ago. If in doubt, the Signal wire is usually on the inside face of the three pins.
lakeshore
« Reply #6 on: October 17, 2012, 04:33:53 pm »
I thank you kindly for the info.
John.
Subculture
    • Dive-in to Model submarines
« Reply #7 on: October 17, 2012, 06:16:43 pm »
I recently rewired a couple of old Sanwa servos with the old wiring, converted them to JR connectors.
Page created in 1.143 seconds with 17 queries.
