Author Topic: Is This A Dead Battery?  (Read 4720 times)
sailorboy61
« on: November 18, 2012, 05:08:36 pm »
I have an SLA inherited with a boat I bought. Whilst it charges and I can measure some voltage across it, it 'rattles' if shaken. I am assuming this is some dried out cell material and as such the battery is effectively no good for the designated voltage and current?
Tnx
Re: Is This A Dead Battery?
« Reply #1 on: November 18, 2012, 05:19:19 pm »
Doesn't sound good.
Does it hold it's charge overnight ?  Will it drive a motor ?
Ken
sailorboy61
« Reply #2 on: November 18, 2012, 05:21:01 pm »
Not tried it in a boat recently, but its certainly holding charge, albeit less than rated, sp I suspect its only one dead cell.
« Reply #3 on: November 18, 2012, 05:22:22 pm »
I suppose it would be ok.  Keep an eye on the voltage I suppose
Ken
« Reply #4 on: November 18, 2012, 05:25:44 pm »
Any rattle on any battery is bad news.  But if it will take, hold and deliver a full charge, it's OK.
With an SLA, just one ropey cell is a dead battery.  That's what "sealed" means.
cos918
« Reply #5 on: November 18, 2012, 05:33:25 pm »
The battery
is knackered. Any rattle means it on its way out. It will only be holding a limitted charge. A 12v 7ah bat will still show 13v with ony 0.5 ah left in it. Time to think about getting a new battery.
sailorboy61
« Reply #6 on: November 18, 2012, 05:35:09 pm »
Thanks all new battery to be ordered.
alan colson
  • I Just Dabble In Model Boats
« Reply #7 on: November 19, 2012, 03:27:25 pm »
the rattle you can hear is the gel inside the battery that has crystalized. Alan
ukmike
« Reply #8 on: November 19, 2012, 05:50:29 pm »
Tnx
Simple answer.
Yes.
Mike.
dreadnought72
« Reply #9 on: November 19, 2012, 07:48:15 pm »
Additional answer - dead batteries make great weights for:
1/ holding things together while glue dries
2/ ballast
Andy
« Reply #10 on: November 20, 2012, 09:43:17 am »
2/ ballast
Andy
And door stops
john s 2
« Reply #11 on: November 20, 2012, 06:17:45 pm »
Just out of interest. What could be added into a gell cell to revive the gell if its drying out? Many so called maintenence free car batterys fail because of electrolyte loss and just need good old distlled water to keep the cells covered. John.
« Reply #12 on: November 20, 2012, 06:24:39 pm »
Once the plates are exposed they can distort and that writes the battery off. Once a lead acid battery is damaged then there is very little indeed you can do to revive it which is why it is so important to keep to the recommended charging regime.
grendel
« Reply #13 on: November 20, 2012, 06:36:47 pm »
nothing - they are sealed units so no maintenance is possible - the acid is in a jellified form (so it doesnt spill), but this makes it impossible to refill (plus as the battery can be used in any orientation there are no access ports).
Grendel
« Reply #14 on: November 20, 2012, 09:24:58 pm »
Being sealed does not prevent the battery venting under misuse or old age.  It does prevent it from being refilled.  Sealed = sealed for life = when its dry, its dead.  Ready for its new life as ballast or a doorstop or a gluing weight.
Bill D203
  • not long now!!
« Reply #15 on: December 07, 2012, 08:44:05 pm »
And door stops
A door stop is Ok but haveing somthing to lob at the local yobs round here would be another use. :}  As a model battery RIP.
Page created in 0.029 seconds with 18 queries.
