Author Topic: Proxxon table saw blade  (Read 5117 times)
steam up
« on: December 22, 2012, 07:01:19 pm »
Try as I might no amout of effort seems to move the retaining bolt holding the blade on the shaft >>:-( >>:-( >>:-( .
I have tried locking the drive shaft using an alan key and have managed to bend the key %% %% .
I'm not even sure if its a left or right hand thread I am open to suggestions as I'm running out of ideas.
Liverbudgie2
Re: Proxxon table saw blade
« Reply #1 on: December 22, 2012, 07:08:52 pm »
Which saw is it, the big one or the little one?
LB
steam up
« Reply #2 on: December 22, 2012, 07:24:05 pm »
Its the big one,thinking back I am sure I have problems last time I changed a blade.
mrsgoggins
« Reply #3 on: December 22, 2012, 09:15:13 pm »
Left hand thread?
Chasing perfection but not running fast enough!
Liverbudgie2
« Reply #4 on: December 22, 2012, 09:15:41 pm »
I've just had a look at mine and I see your point.
I have changed mine as well in the past but now it appears to be on tighter than ever. The only way to do it I think if you have not already done so, is to remove the plate on the table and using a long hex key and jam the blade to stop it turning. Crude I know but, it has worked in the past. I'm pretty sure that it's a normal thread on the locking screw.
LB
chipchase
« Reply #5 on: December 22, 2012, 09:18:53 pm »
 Hi steam up; I have the same saw fortunately I have had no problem changing the blades. You have not mentioned anything about having the operating manual. Here is a link to the operating manual just in case you do not have one.
Regards Brian
  https://www.proxxontools.com/store/pc/catalog/manuals/37070%20fet%20table%20saw%20manual%20eng.pdf
« Reply #6 on: December 22, 2012, 10:04:13 pm »
Here is a Video on the latest Proxxon table saw.....I have the older FKS-E model ....Proxxon are expensive machines but are of supurb quality  :kiss:  Derek
http://youtu.be/HqiVLQ78y7Y
steam up
« Reply #7 on: December 23, 2012, 06:19:16 pm »
Needed a total strip down in the end >>:-( >>:-( .
Anti clockwise to remove bolt after knocking the shaft out and placing in the 3 jaw chuck.
Liverbudgie2
« Reply #8 on: December 23, 2012, 07:33:53 pm »
Do you mean that it is a left hand thread after all? I also have the earlier model but I've never had the instruction manul for it now I know where to find it. The later model appears to be a much better machine as well.
LB
giovanni
  • Live Steam Power
  • 1906 Stanley Landspeed Record Car
« Reply #9 on: December 24, 2012, 12:13:41 am »
I love these tools.
I have the Proxxon bandsaw, micro belt sander, rotary hand drill and assorted accessaries.
My next Proxxon tool acquisition will be the table saw.
Kind regards,
Giovanni
