Author Topic: Bogstandard engine  (Read 2758 times)
steam up
Bogstandard engine
« on: December 26, 2012, 11:26:13 am »
Over the Chrismas break I have been looking at the Bogstandard engine as the building board (kitchen table has been put to other uses %% ).
Has anybody ever tried the build using imperial kit? All my equipment is imperial and I don't think purchasing metric for the project is an option.
Re: Bogstandard engine
« Reply #1 on: December 26, 2012, 11:40:11 am »
DON't try to do direct conversions for all the bits. If you understand engines, then make the parts that are supposed to fit together fit. 25mm CAN be 1" if it isn't linked to the timing.
steamshed
« Reply #2 on: December 26, 2012, 01:01:07 pm »
Hi Steam Up
If its BOG's ocillator I have one of his originals that you could borrow and Mic up, if this helps
steam up
« Reply #3 on: December 26, 2012, 01:15:46 pm »
Thanks for the very kind off.
Its actually the slide valve engine I am looking at.
frazer heslop
« Reply #4 on: December 26, 2012, 08:21:31 pm »
Like you my kit is imperial and I build a lot of metric sized engines just using 25.4 and going to the nearest Imp size for bearings and bushings
BarryM
« Reply #5 on: December 27, 2012, 09:56:46 am »
I built Bogstandard's twin cylinder, piston valve engine to his metric dimensions. However, I used BA threads rather than metric as I had no small metric taps or dies. This did not cause any problems.
Barry M
Page created in 0.32 seconds with 17 queries.
