Once you get used to the Neptune, you'll find they are super boats...I've had three now, and the one I have now is well and truly sorted, and performs flawlessly every time it sees water.
I've tried using it with the stock 'planes, the front 'planes removed, the rear 'planes removed, and to be honest, there's not a lot of difference. It now has a set of Robbe U-47 rear 'planes on the front, and the stock Neptune front 'planes on the rear, and that setup seems to work very well.
As Andy says, the best modification you can make is to swap the original 12v gel cmp.uell for either a set of high capacity niMhs or liPos. I have a pack of 3700a/h niMhs for mine, when this arthritis allows I will swap the batteries over. Another AMS member, Paul Cook, has a 12v 5000a/h niMhs pack in his, and it seems to run forever.
Mine has had several external modifications made to it(see attached image)and uses a Robbe F-14 radio...I like the slider switches for use with the ballast pump.
