Author Topic: Project MPM OuterLimits XXX  (Read 2649 times)
MPM
    • MillPond Models
« on: January 22, 2013, 11:34:33 pm »
Hi Guys,
Im going to do a build thread of my Outerlimits XXX. The plan of attack is to have steerable drives, 1:1 CrossBox and clutch and dual waterpumps with a RCMK 520 Bottom end with Tuned MPM Zenoah 28.5cc Heads resulting in a 57cc Engine. Once everything is fitted it will be going to be airbrushed.
Ive starting marking out the transom with the steerable Werner D Drives. This takes abit of time... Im very limited to room so im leaning over the gear drives to pull them up further... The result is that some angles need alot of thinking about and have to be changed!!
Hope you like so Far.
colin123
Re: Project MPM OuterLimits XXX
« Reply #1 on: January 25, 2013, 03:13:15 pm »
looking good so far :-))
MPM
    • MillPond Models
« Reply #2 on: January 25, 2013, 04:19:14 pm »
Cheers Colin. Ill try and get abit more done this evening!!
gwa84the2nd
« Reply #3 on: January 26, 2013, 05:01:32 pm »
them drive look well trick hope they perform as well as they look  :-))
