Author Topic: Prop - Shaft - Tube - Coupling - Motor Help for a beginner please!!  (Read 8187 times)
dave parker
Hi all
Go gentle, new starter here....
I am starting to accrue components to start my very first foray into model boat building but have come across an issue I am not sure if is normal or not.
I have got a 10" JP Accesories Prop Shaft, M4 threads both ends, 6mm Diameter tube etc etc, and also a plastic 3 bladed M4 threaded propeller.
When I screw the propeller on to the end of the shaft it tightens but there is still 5-8mm of thread left showing.
I have just been into my local model shop and been told that i need to cut back the threaded end of the shaft so that the prop tightens onto the nut and washer next to the bearing, something about not transferring the loads through the motor?
He walso went on to say that the other end that connects to the coupling isnt as important and is fine to have some threads on show providing it has a good connection to the coupling.
Is this correct?
Can someone maybe go through thte basics of Prop - Shaft - Tube - Coupling - Motor connections with me?
Many thanks in advance
sailorboy61
Re: Prop - Shaft - Tube - Coupling - Motor Help for a beginner please!!
« Reply #1 on: January 29, 2013, 01:25:30 pm »
I think you'll find the idea of the nut and washer on the prop end is a lock nut. Obviously you tighten it one way, and in an ideal world this would be the ahead direction of the propellor so it naturally 'tightens' onto the shaft for what in most cases is the majority of the running time. Now conversley when you go astern, that would mean unscrewing the prop from the shaft, but the idea then is the locking nut is tight against the prop so it cant move. I would also use some threadlock - it comes in several strengths, go for the minimum!
dave parker
« Reply #2 on: January 29, 2013, 02:26:56 pm »
Thanks Sailerboy61
I am confused as to whether the nut and washer should tight up to th bearing then the prop tight uo to that, or do i tighten the prop as far as it will then loosen the nut back till its tight to the prop and not the bearing??
CONFUSED?!?!?!? {:-{
sailorboy61
« Reply #3 on: January 29, 2013, 02:31:23 pm »
Tight to the prop. If its tight against the bearing will cause friction and that will overload the motor, drain battery and other bad things...................... >:-o
black magic racing
  • when winning is all . it stops being a hobby
« Reply #4 on: January 29, 2013, 02:33:22 pm »
tighten the nut to the prop you want a little bit of movement,i would not put it tight to the bearing :-))   kurt  black magic racing
FAST is never FAST enough
Black Magic Racing with BMPRS    Telford Model Boat Club
Birkenhead Model Power Boat club Vice Commodore
dave parker
« Reply #5 on: January 29, 2013, 02:43:19 pm »
Hmmmmm
Forgive me for sounding dim but that would mean that there is 5-8mm of propshaft thread between the nut and the bearing and so the shaft can move up and down in the tube by this amount?
Where should the washer be?
Does that make sense?
« Reply #6 on: January 29, 2013, 02:53:51 pm »
Hi Dave,
Welcome to the Mayhem!
Give me a ring, PM sent.
  Martin
sailorboy61
« Reply #7 on: January 29, 2013, 02:56:15 pm »
5-8mm is probably a little excessive, 2-3mm would be acceptable to me, so perhaps you could trim a tiny bit from the shaft without damaging the thread. There is probably allowance for thread to take into account different size props and depth of thread. The shaft shouldnt really move around in the tube too much if the coupling is well aligned - it is held at both ends of the tube by bearings.
The washer should go between nut and prop in my book at least.
dave parker
« Reply #8 on: January 29, 2013, 03:09:01 pm »
So am I right in thinking when running the prop pushes the shaft which then pushes on the coupling and into the motor which is fixed to the boat?
sailorboy61
« Reply #9 on: January 29, 2013, 03:43:18 pm »
« Reply #10 on: January 29, 2013, 03:48:45 pm »
And ruins the motor bearings  >>:-( >>:-( >>:-(
dave parker
« Reply #11 on: January 29, 2013, 03:50:38 pm »
So is that not right then Ned?
« Reply #12 on: January 29, 2013, 03:58:29 pm »
The washer at the prop end should be between the locknut on the prop and the tube with no more than about a millimetre of play.
It then acts as a thrust washer transmitting the thrust from the prop to the hull via the stern tube.
If all the thrust is on the motor bearings they are not going to last very long.
sailorboy61
« Reply #13 on: January 29, 2013, 04:01:28 pm »
Already reduced the gap in an earlier post...................
« Reply #14 on: January 29, 2013, 04:08:09 pm »
But not enough
« Reply #15 on: January 29, 2013, 04:48:09 pm »
Threaded section should end just before the washers.
Threaded end can / should be cut down to suit internal length of prop.
 ( use a 'Dremel' & a cut off wheel - NOT a vice and hacksaw! )
Should be no more than 1mm-ish 'slop / play' lengthwise.
Some propshaft can be longer than the stuffing tube and a collar used inboard to hold the shaft in place.
Den W
« Reply #16 on: January 29, 2013, 05:30:06 pm »
In a word, the unthreaded part of the prop shaft should be about 1/8" or 3.25mm longer than the prop tube .thus giving you enough space to incorporate a teflon washer at each end .as per Martins diagram.. :-)) :-)) :-))
1 Small Part of  "OMRA,s" Great Team
scoop
« Reply #17 on: February 10, 2013, 02:04:13 am »
And don't forget to fill the stuffing tube with grease to stop water coming back up the stuffing tube and flooding the hull when going astern, if using teflon washers don't use teflon grease use a petrol based one such as Castol LM
Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
« Reply #18 on: February 10, 2013, 08:40:33 am »
Where is a good place to get teflon washers? need some 4mm id x 6mm od
Den W
« Reply #19 on: February 10, 2013, 09:24:21 am »
Hi, if you have access to a lathe ,you could try -- Gilbert Curry Industrial Plastics Co Ltd
   16 Bayton Road Exhall,  Coventry, West Midlands CV7 9EJ
..they will supply you with any size (within reason)  solid teflon bar, and you can turn it down to what ever size you require at a fraction of the high street cost...hope this helps
scoop
« Reply #20 on: February 10, 2013, 09:45:48 am »
Try astec models .....www.astecmodels.co.uk, type in teflon washers in the search and you will find 4 x 7 x 1 mm 8 for £3.90 and pretty close to the size you are looking for, saves firing up the lathe  :-))
Scoop
tmbc
    • www.tmbc.org.uk
« Reply #21 on: February 10, 2013, 09:55:07 am »
hi m8
why buy a piece of teflon bar when you can buy them from prestwich just contact dave there used on fast electrics 4mm id 10 for 2.95 i think i should become a marketing guru finding these cheaper prices  {-) {-) {-) {-) {-) {-) !!
BMPRS  Health and Safety Co-Ordinator
scoop
« Reply #23 on: February 10, 2013, 10:58:42 am »
hi m8
Nice spot  'Guru' I forgot all about Dave's FE pages on his website !
Essex.....www.prestwich.ndirect.co.uk/ or he trades on ebay under winninisall   :-))
Den W
« Reply #24 on: February 10, 2013, 11:53:57 am »
THE SELF SATISFACTION YOU GET FROM MAKING YOUR OWN BITS AND PIECES FAR OUTWEIGH ANY COST OF READY MADE (you never know what your going to get)...THIS IS  M-H-O and I,m not trying to out-do anyone else....  :-)) :-)) :-)) :-)) ..ps If you PM me I will gladly make you some when I get back from hols..  FREE  including postage  "simples"
