Author Topic: Glynn Guest 'Dusty Miller' Free Plan  (Read 10829 times)
goBulawayo
« on: February 18, 2013, 07:47:38 pm »
Hi All, has anyone built the free plan 'Dusty Miller' tug that came in Model Boats sometime in 2008? Attached pics show my progress so far, this tug will be fitted with an electric motor not steam as per the magazine build.
Wayne
Re: Gkynn Guest 'Dusty Miller' Free Plan
« Reply #1 on: February 18, 2013, 07:49:09 pm »
 Not me but my friend Wayne in Wales seems to making a good job of one!   :-))
« Reply #2 on: February 18, 2013, 07:58:29 pm »
 No me but my friend Wayne in Wales seems to making a good job of one!   :-))
Good grief Didnt know you had a Friend at all
ardarossan
« Reply #3 on: February 18, 2013, 08:11:43 pm »
It was a Typo - He meant Fiend!
Andy
How much wood would a Woodchuck chuck, if a Woodchuck would chuck wood?
davidjt
  • north wales coast
« Reply #4 on: February 18, 2013, 08:37:14 pm »
hi wayne,
it is nice to see some one makeing a good job of tug boat from free plans, you will learn a lot from doing this, then find you want to try more difficult types of builds ie plank on frame %%  keep up the good work
david
« Reply #5 on: February 18, 2013, 08:39:44 pm »
 I have lots of friends..... just because they don't know me.....!   ;D
goBulawayo
« Reply #6 on: February 18, 2013, 09:34:14 pm »
hi wayne,
 david
Hi David, this is practise for my plank on frame yacht that I started a while back, see http://www.modelboatmayhem.co.uk/forum/index.php?topic=39179.0
Wayne
goBulawayo
« Reply #7 on: February 22, 2013, 08:42:54 am »
not much progress but she is coming together
Wayne
goBulawayo
« Reply #8 on: February 23, 2013, 03:27:39 pm »
The build article for this boat says to coat with a number of coats of cellulose dope in various dilutions. Is there anything cheaper that I could use as the dope seems to be really expensive. I bought a 125ml tin but at about £5 I can see myself needing to spend a lot more to do the 5 odd coats plus then another coat with tissue paper - I take it this will fill any minor gaps in the timber? Or at least the tissue paper will - Thanks Wayne
TheLongBuild
  • Build em, and play hard..
« Reply #9 on: February 23, 2013, 03:32:35 pm »
I would have thought that 2 layers would be ok.. 1 coat lightly sand then 1 more.
goBulawayo
« Reply #10 on: February 23, 2013, 03:56:55 pm »
Thanks, would you dilute the first coat?
W.
TheLongBuild
« Reply #11 on: February 23, 2013, 04:00:44 pm »
Me personally probably not.
goBulawayo
« Reply #12 on: February 23, 2013, 04:04:10 pm »
Cool thanks
goBulawayo
« Reply #13 on: February 26, 2013, 08:07:10 pm »
Progress last night, busy finishing the skinning tonight (I hope)
Wayne
goBulawayo
« Reply #14 on: March 04, 2013, 05:10:41 pm »
Progress to date, 3 coats of cellulose dope added to hull, 2 to superstructure which has been primered.
goBulawayo
« Reply #15 on: March 17, 2013, 08:25:31 am »
Slowly getting there, I have actually started painting the hull, but am behind re taking pics
goBulawayo
« Reply #16 on: June 09, 2013, 05:41:19 pm »
This is actually my third sail with this tug, but she is now properly ballasted and has a different motor (rather noisy it is though)- Few details to sort out and she is done. Is a fun little boat. She does nose dive a little under full power
Wayne
and a bit of video
http://s297.photobucket.com/user/gubulawayo/media/DSCF2476.mp4.html
« Reply #17 on: June 14, 2013, 01:56:44 pm »
Throaty sounds there, Wayne.  Very impressive.
Try a little strip of lead sheet low down in the stern.   ok2
goBulawayo
« Reply #18 on: June 14, 2013, 03:07:07 pm »
Thanks Ken, will try that, though there is not much 'low down' area in the stern - I just need to not apply full power thats all -  Wayne
« Reply #19 on: June 14, 2013, 03:12:29 pm »
You might like to try wrapping a 2 inch strip around the prop tube.    :}
goBulawayo
« Reply #20 on: June 14, 2013, 03:28:01 pm »
OK, will try that - Wish I could get rid of that vibration noise, I tried mounting the motor on a rubber strip but it did not help - The geared motor is quite noisy itself and it's transferring onto the hull and echoing around the inside - Anyway it will do it was only an 'easy' first build - Now to continue with my yacht and maybe start my Lake Kariba ferry.
Wayne
goBulawayo
« Reply #21 on: August 14, 2013, 06:52:31 pm »
Been adding a bit of detail to my Glynn Guest tug today, decals from various bits in my decals box, plus a tow hook. I added brass portholes a few weeks back and I have a few lego people to add to the boat, there is one in the cab at present
Wayne
Page created in 0.034 seconds with 18 queries.
