Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: My African Queen!  (Read 55649 times)
muleears
Re: African Queen started at last....
« Reply #75 on: June 21, 2013, 02:24:34 pm »
Nick,
With what did you paint the boiler and lagging?  Was it ia hi temp paint?  How are you going to simulate the rust?
Cal
Washington, NC USA
Proud owner of:
75% complete Krick Victoria
75% complete Billing African Queen
Krick Alexandra
Lots of building, very little steaming!
pettyofficernick
  • Marineville will be destroyed, Muahahaha.....
« Reply #76 on: June 21, 2013, 05:39:57 pm »
Hello Cal, I used standard Humbrol enamel, I am hoping the paint on the top of the boiler will blister a bit, to add to the shabby appearance. As far as rust go's I will either use a weathering produce as supplied for model railways, or, mix some iron filings with a little paint and daub it on here and there, when it is dry, a light sanding of the surface will expose the iron filings and the should rust naturally. Well, I hope it will anyway. If anyone has any rusting tips, please add them, I'm all ears.....
What I do is best not discussed, for I have been many things in my time....
muleears
« Reply #77 on: June 29, 2013, 09:29:07 pm »
Nick,
Any progress on the AQ?  I'd like to see some pics!
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pettyofficernick
« Reply #78 on: June 29, 2013, 09:37:12 pm »
Hello Cal, nothing since finishing off the engine, now that Summer is here and I work 3 nights a week, progress has slowed a little, I have also been taking advantage of the lighter evenings to sail Victoria. Fear not, there will son be a burst of activity, I need to get it finished as I have other projects backing up.....
« Reply #79 on: June 30, 2013, 04:53:02 am »
There will son be a burst of activity
Get it on video Nick - that's rare enough stuff to call in David Attenborough.  {-)
muleears
« Reply #80 on: July 26, 2013, 06:35:34 pm »
Still looking for that "Burst of activity" Nick!  I want to see this boat come together! And see some video of it on the water!
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pettyofficernick
« Reply #81 on: July 26, 2013, 06:47:06 pm »
And so you shall Cal, in the fullness of time I was only looking at it a couple of days ago, and thinking 'I must crack on with this' The weather has ben keeping me outdoors for the last couple of months, once it has cooled down a bit I will resume operations...... :-)) :-)) :-))
muleears
« Reply #82 on: July 26, 2013, 06:49:12 pm »
That's good to hear Nick, your building expertise is an example I need!
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pettyofficernick
« Reply #83 on: September 15, 2013, 05:42:44 pm »
Work has resumed at last, I have made and fitted the rudder this weekend, a straight forward fabrication job and all went according to plan.  The mounting blocks/bearings started life as two strips of 1/4 x 1/8 brass flat soldered together, all holes were then drilled and tapped 8ba where necessary and then un soldered, so everything lines up nicely.  Unfortunately, I broke one of the brass screws that hold the support bar to the keel, I guess I will have to live with that as I will damage the hull trying to remove it. Just need to work out how I am going to operate it now, I have a couple of ideas, all will no doubt be revealed in the fullness of time.
muleears
« Reply #84 on: September 15, 2013, 10:25:59 pm »
Looks great Nick!  Can't wait to see it progress.
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
« Reply #85 on: September 16, 2013, 03:30:10 am »
Yes Nick, looking good. I will have to pay you a night visit O0
SailorGreg
« Reply #86 on: September 16, 2013, 03:08:59 pm »
Nice to see your progress Nick.  Have you found your Humphrey Bogart and Katherine Hepburn yet?
As the AQ had a tiller, had you considered using a whipstaff arrangement, with a servo right under the tiller operating a vertical fork engaging with the tiller?  Not strictly to scale, but perhaps less intrusive than  other connections.  Just a thought.
Keep going - looking forward to the next progress report.   :-)) :-))
Greg
pettyofficernick
« Reply #87 on: September 16, 2013, 03:15:38 pm »
Hi Greg, the whipstaff is the way to go I think, with a slight difference, I am considering 2 tillers, the main 'scale' one, and another through a slot in the transom, lower down, so all the 'works' will be hidden under the stern bench.... :-)) :-))
pettyofficernick
« Reply #88 on: May 18, 2014, 04:02:06 pm »
Greetings all, I have made progress! After another bout of inactivity, I am once more back in harness and cracking on with the job. I attempted, some time ago now, to effect control of the engine by using Bowden cables, this was not a success, I think due to the bends being too tight. You will see from the photo how cramped everything turned out, as I was trying to keep the servos in the small space beneath the bench seats.
The upshot of all that was, I removed the lot and started again. So, back to a blank canvas, so to speak. This time, I decided to use conventional push rods, with the servos along side the engine. I used Hi Tec medium sized metal geared ones, and they will be hidden under the gin crates. First job then was to plank the deck in, I have used 10mm x 1mm oak for this....
Stripped out ready for take 2....
Planked and ready for servos....
All done..
Testing day, just visible is the steering servo, with the 'second tiller' arrangement, I will take a photo later for those who are interested
There are a couple of leaks to sort out, one in the feedwater line, and one on the main steam pipe, I mush have knocked it when working on the regulator control. Still not used any ply yet, hoping not to have to use any. Finally, a link to a video of the Queen getting het bottom wet for the first time a couple of days ago. Please forgive the watermark, used an on line video editor to make the file smaller for uploading.
https://www.youtube.com/watch?v=yBjhvdFmGFI&feature=youtu.be
Jerry C
« Reply #89 on: May 18, 2014, 04:30:58 pm »
Looking great dere la! What are the hull dimensions? She looks similar to mine but appears to carry more weight. She certainly rides higher than Wear which is overloaded a bit. I'm looking for a GRP hull about 4' to 5' with a hefty beam on her for the new plant.
Jerry.
pettyofficernick
« Reply #90 on: May 18, 2014, 04:35:52 pm »
Hi Jerry, she is the Kingston moldings African Queen hull 36" x 10 1/2", she is riding high at the mo, more weight to go in yet, 30 odd brass angle frames, brass knees, Mahogany upper deck, but I think it will take it quite easily. The hull is a work of art, beautifully molded, and ready trimmed.    http://www.kingstonmouldings.co.uk/pdafricanqueen.htm
pettyofficernick
« Reply #91 on: May 19, 2014, 10:06:52 am »
Here is a photo of the tiller arrangement, simply a servo connector minus the securing screw, through which the operating tiller slides when steering, simple and effective, it gives 45 deg, either way, and is all hidden under the bench.
pettyofficernick
« Reply #92 on: May 24, 2014, 02:34:42 pm »
Nice parcel in the post this morning, the gas tank has arrived, nice an big for long voyages....
SailorGreg
« Reply #93 on: May 24, 2014, 08:16:40 pm »
Nice to see the AQ moving along again Nick.  Your "second tiller" looks like it will be just the job to do some hidden steering  :-))
Looking forward to following the rest of the build.
Greg
pettyofficernick
« Reply #94 on: May 24, 2014, 08:22:40 pm »
Thanks Greg, as you can see, I am trying to build in the 'distressed' look, as I wan't the finished job to look as tatty as the real AQ, hence the oil stains on the decking etc.....
Jerry C
« Reply #95 on: May 24, 2014, 08:30:08 pm »
I love a parcel, especially with a shiny thing in it.
Jerry.
pettyofficernick
« Reply #96 on: May 24, 2014, 08:34:22 pm »
Jerry.
Ha ha ha ha ha, so do I, I lie in wait for postie, and fling open the front door before he is even through the gate......
SailorGreg
« Reply #97 on: May 24, 2014, 11:08:36 pm »
I bet you two refuse to go to bed on Christmas Eve in case Santa misses your house!
pettyofficernick
« Reply #98 on: May 24, 2014, 11:13:50 pm »
You can imagine the fuss when I come home and find one of those red cards......
muleears
« Reply #99 on: May 25, 2014, 03:55:07 pm »
Your AQ is looking good Nick!  I look closely at all your pics and frequently find something I can use in one of my builds.  You are a building genius! :-))
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
Pages: 1 2 3 [4] 5 6   Go Up
