Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: Building the FV Cornelia Marie  (Read 184151 times)
missyd
Re: Building the FV Cornelia Marie
« Reply #125 on: February 11, 2014, 04:35:55 pm »
@Mike. The picture on the trolley was made around 4pm ... no sun ...
I never built such a nice model by myself and without plans ... you'll learn things the more you build on a model ship.
Here a picture directly in the sun around noon! Big difference in color. And I must say its still lighter as on the picture! It is very difficult to find the right color! I have pictures all with different shades of blue and even some where she looks like she has a green color. It must be the light situation in Alaska that changes the color from day to day ....
Worked on the bow today ... I want to finish it asap ... the n I can put on the blue paint outside.
And to end the day I turned the foundation of the crane on my lathe. Looks alright for me.
Thats all for today ...  ok2
Danielle
missyd
« Reply #126 on: February 13, 2014, 02:48:38 pm »
Today I finished the anchor winch ... the chain is too small and was used only for taking the pictures ...
Danielle
missyd
« Reply #127 on: February 17, 2014, 11:05:44 am »
Danielle
missyd
« Reply #128 on: February 20, 2014, 01:40:13 pm »
Just some pics from the built ... if there are questions please feel free to ask!
Danielle
missyd
« Reply #129 on: March 04, 2014, 05:29:46 am »
New pics of my built! Its getting on very slowly ... %)
Try out of the Lamp with 2x12V LEDs in it. Just very nice!!!!!
Danielle
MikeK
  • Utter Bloody Chaos !!
« Reply #130 on: March 04, 2014, 07:58:12 am »
Great detail work Danielle ! Wish I could match it  :-))
missyd
« Reply #131 on: March 04, 2014, 03:39:56 pm »
thanks a lot Mike! I wish I would build in 1/24 or 1/16 scale to add even more details ....  ok2
Danielle
Das boot
  • Build like there´s no tommorrow !!!
« Reply #132 on: March 08, 2014, 10:39:00 pm »
I think Capt. Phil have a big smile on, when he look down from heaven and see your beautyfull and detail work on his beloved Cornelia Marie  :-) . Keep up the good work  :-)) .
Best Regards Brian..
« Reply #133 on: March 08, 2014, 11:04:58 pm »
missyd.........great progress...I like the matt blue paintwork..... :-))
Have you checked the discharge angle of the five exhaust pipes?........not the angle of the pipes them selves  ;)....but the cut off angle of each pipe mouth ....................Derek
missyd
« Reply #134 on: March 09, 2014, 06:23:47 am »
Yes I have checked the angles ... I took the angles from different pictures but non was 100% clear to say the angle is exactly xy°.... please note that I build my CM without any drawings or measurements .... ok2
Some more pics from my build ...
Danielle
Mark T
« Reply #135 on: March 09, 2014, 09:22:14 am »
Your build just gets better and better  8)
That CM is looking really great!
missyd
« Reply #136 on: March 11, 2014, 03:59:14 pm »
Thanks a lot Mark! :-))
Some new pics ...  ok2
Danielle
« Reply #137 on: March 11, 2014, 04:19:27 pm »
[/quote
Have you counted the rivets on Phil's jeans? :D
missyd
« Reply #138 on: March 11, 2014, 04:54:40 pm »
Good point Ned!!! :-))
Danielle
missyd
« Reply #139 on: March 15, 2014, 12:35:20 am »
Some new parts finished...
Danielle
missyd
« Reply #140 on: March 15, 2014, 12:40:54 am »
Two of the four crab tanks have a live water future! Its driven by a 12V waterpump that actually runs on 6V.
We installed a quick test setup in the kitchen to see if everything is working ... to my surprise everything worked as planned.
Anita my wife took the video ...
http://www.youtube.com/watch?v=uFVZS7iCcpY
Danielle
MikeK
« Reply #141 on: March 15, 2014, 08:24:46 am »
Still looking great, is it starting to feel a bit heavy by now ? The idea of pumping water into the model, then presumably overflowing across the deck a la the overflowing tanks of the CM is certainly a novel addition, if not a little unnerving ! The idea of introducing water from the outside into the model goes against the instincts  :embarrassed:
missyd
« Reply #142 on: March 15, 2014, 11:03:53 am »
You're right Mike. A very special feature. Actually I had planned to include a big waterfilled tank in the front compartment. But I have not figured out how to do it in a safe way and so I decided to delete it from my plans. Weight is really no problem. 25kg minimum are needed to get the Cornelia Maria on the waterline. We'll see if everything works out as planned.
Danielle
MikeK
« Reply #143 on: March 15, 2014, 12:54:32 pm »
I think you might be surprised at the loss of stability if a larger tank were to be allowed to slop around. The Free Surface Effect can be considerable - I speak with many stressful experiences of loading full size ships when stability was tight, in the 'good old days'  >:-o
chris gillespie
« Reply #144 on: March 15, 2014, 01:26:43 pm »
I have played with such an idea myself...
the solution to stop the swishing is,
on the inside of the tank, we have a lid maybe glued to some foam this will rise and fall with the amount of water....this lid will be fixed on a runner either side of the tank, which means it can only rise with the amount of water, the runners will be made in such a way that they can only work together...i.e when the boat is level the water can be put into the tank, when the boat is not level the runners wont work, ( prevents sloshing about )
in theory it works in my head...... {-) {-)  ........not got round to practical installation and trials yet though
missyd
« Reply #145 on: March 15, 2014, 06:09:42 pm »
Chris and Mike ... you're both right. I would have added sloshing boards to the inside of the tanks just like they have on some boats ...
Danielle
« Reply #146 on: March 15, 2014, 06:49:27 pm »
Alternatively - install clear thin (.5mm) plastic baffles - egg crate/ice cube tray shape - interlaced fingers square pattern about 3/4 depth of the water with a reasonable number of holes - the holes allow the water to circulate, the baffles add resistance to the water moving about too much, like what they have in fluid road tankers - clean and thin so they 'disappear' in the water - just a thought if in full view, if not on show, just put the baffles in
missyd
« Reply #147 on: March 15, 2014, 07:38:36 pm »
Exactly what I wanted to do ....  :-))
Danielle
MikeK
« Reply #148 on: March 16, 2014, 08:20:52 am »
On a full sized ship the double bottom ballast and fuel tanks all have inter-plates with lightening holes in them similar to the baffles you mention. Lets say there is a strong breeze when the model is on the water, all models naturally heel a bit to the wind and it is at this prolonged lying at an angle that allows the tank water to percolate through the baffles and across to the low side and increase the list. Bobbing about on the waves indeed helps cancel out the heeling effect.
 Not saying for a moment that it is instant gloom and doom ! just to be aware.  :-))
missyd
« Reply #149 on: April 07, 2014, 05:04:18 am »
New Job found. I'already back to work. Some new pictures from the built.
Got the new RC very cheap!
Danielle
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16   Go Up
Page created in 0.033 seconds with 18 queries.
