Author Topic: which motors  (Read 5965 times)
wicker
which motors
« on: April 16, 2013, 09:30:27 am »
which motors would you good modellers recommend for a model of the flying spindrift
wicker
Re: which motors
« Reply #1 on: April 18, 2013, 07:12:06 pm »
this tug has 2 60mm props with steerable korts  come on now boys any help
Re: which motors
« Reply #2 on: April 18, 2013, 07:21:32 pm »
900 series motors most defo
wicker
Re: which motors
« Reply #3 on: April 18, 2013, 07:22:55 pm »
Thanks Dave now with or without gearbox
Re: which motors
« Reply #4 on: April 18, 2013, 07:25:18 pm »
Direct drive you do NOT need a gearbox with these motors....and before you ask Try Steve Taranter Model boat bits he has some caldercraft ones in stock and he aslo does the Ali Mounts for them.
wicker
Re: which motors
« Reply #5 on: April 18, 2013, 07:29:09 pm »
thank again Dave I am not really up to the electric==Charlie
Tug Fanatic
Re: which motors
« Reply #6 on: April 19, 2013, 07:24:44 pm »
Interesting.
The 900 motors that I have noticed previously (Graupner) run at about 6000rpm. Whilst I am used to endless windings of 500 motors I hadn't realized that the same was true for the bigger motors. These run at 300rpm which obviously makes them better for bigger props. What is considered the best tug prop for these?
kmmbcwebmaster
    • Kingsmill MBC
Re: which motors
« Reply #7 on: April 19, 2013, 07:53:02 pm »
Have used the caldercraft 900 motors in my MMM Eurogirl with 40mm korts and been very impressed with the torque these motors have .
just tugging along
wicker
Re: which motors
« Reply #8 on: April 19, 2013, 09:18:26 pm »
I have two 60mm props any good for that motors
Perkasaman2
Re: which motors
« Reply #9 on: April 19, 2013, 09:44:14 pm »
The most important feature for high torque lo speed running 900 brushed motors is that they should/ will be 12 pole.  :-)
Re: which motors
« Reply #10 on: April 19, 2013, 09:56:49 pm »
Tug Fanatic these motor will swing a 5ins 4 bladed prop at 6v with ease and also it will run a 55mm 2 bladed prop at 24v
These motors are so so versitile
chipchase
Re: which motors
« Reply #11 on: April 19, 2013, 11:27:55 pm »
Hi Wicker, it’s been quite a while since I built the Flying Spindrift (about six years) the first motors that I fitted were MFA 800 torpedo 2:1 belt drive reduction units. These units worked OK but seemed to lack a bit of power when needed so the motors were changed for the 850s. There is quite a big difference between these motors as the 800s have an off load rpm of 5,100 and the 850s 9,000. The 850s are still in the Spindrift and I have had no problem with this setup.
Tug Fanatic
Re: which motors
« Reply #12 on: April 20, 2013, 08:50:10 am »
Tug Fanatic these motor will swing a 5ins 4 bladed prop at 6v with ease and also it will run a 5mm 2 bladed prop at 24v
These sound like the equivalent of my beloved heater motors.
Please clarify the 24v prop size.
Chris
wicker
Re: which motors
« Reply #13 on: April 20, 2013, 07:14:37 pm »
Chipchase-Is that 850 with or without the reduction box
Re: which motors
« Reply #14 on: April 20, 2013, 07:31:43 pm »
Main trouble with the MFA 850 motors is that they are very Amp hungry....What I mean is simple really they draw well over 12amps under load and this will result in Very short run times....Been there had the tee shirt gne to 900 Motor simply as they draw so little amps and give LONG run times
chipchase
Re: which motors
« Reply #15 on: April 20, 2013, 09:00:45 pm »
with the reduction belt drive system, i forgot to post a photo show the set up, Dave is 100% right about the 850s being very heavy on the Amps
wicker
Re: which motors
« Reply #16 on: April 20, 2013, 09:54:53 pm »
Thank lads it is now decision time--Charlie
Page created in 0.191 seconds with 18 queries.
