Author Topic: Engine starting  (Read 4008 times)
me3
Engine starting
« on: May 05, 2013, 09:45:10 pm »
I have a model with a Rev Unlimited Pro Race in which does not appear to have a choke on it. (The stock and the Mid Mod version do have chokes on them.) we tried for hours to get it started and found the only way we can start it is to put a small drop of fuel directly into the cyclinder. Also, if the engine is cut via the radio the engine will re-start but if the engine stalls it will not start without putting some petrol directly into the cyclinder. We are using Super Unleaded petrol at 16-1. Are we doing something wrong or does anyone have an idea how it should start?
bigtee
  • BTR PACER
    • http://www.bigteeracing.com/
Re: Engine starting
« Reply #1 on: May 05, 2013, 10:42:38 pm »
hi
what carb does it have on it ?
cheers tony
race it like you stole it ................
Big Tee E 58   D 46
me3
Re: Engine starting
« Reply #2 on: May 05, 2013, 10:52:17 pm »
Unfortunately I have no idea for definite what carb it has on it but it could be a OEM wt-644 carb. I could post a picture tomorrow if that is any help.
Many thanks
bigtee
  • BTR PACER
Re: Engine starting
« Reply #3 on: May 05, 2013, 10:58:01 pm »
hi
there are numbers on the side of the carb , 644 , 257 1048 ect
what are the needles set at high and low ?
cheers tony
Big Tee E 58   D 46
black magic racing
  • when winning is all . it stops being a hobby
Re: Engine starting
« Reply #4 on: May 05, 2013, 11:28:04 pm »
hi,to choke the carb,open the throttle to to about a 1/4 open,place your finger over the carb and pull the starter slowly a couple of times till finger is wet or you can smell petrol,make sure carb needles are set to right amount,ball park i would go for 1 3/4 turn out from closed on low and 1 on high,some will say to go 2 on low,or you could try 1 1/4 on low and 1 1/2 on high,any one of them will start the engine,then its just fine tuning after that,hope this helps? :-))    kurt   black magic racing %%
FAST is never FAST enough
Black Magic Racing with BMPRS    Telford Model Boat Club
Birkenhead Model Power Boat club Vice Commodore
me3
Re: Engine starting
« Reply #5 on: May 06, 2013, 07:00:21 am »
Many thanks Bigtee I will look for the number today when I see it. Thank you very much for the help Back Magic Racing, I will try that. Thanks again.
bigtee
  • BTR PACER
Re: Engine starting
« Reply #6 on: May 06, 2013, 08:00:01 am »
morning
as kurt has said above , h 1 1/4 and l 1 1/2 , tune from there , choke with finger and pull over slowly for 2/3 turns untill finger is wet
cheers tony
morning big bouy  %% %% %% ( kurt )
Big Tee E 58   D 46
scoop
Re: Engine starting
« Reply #7 on: May 06, 2013, 08:56:03 am »
morning
cheers tony
morning big bouy  %% %% %% ( kurt ) and when you have done all that don't forget to fit a carb needle lock so the settings don't come loose which they tend to do under vibration when the engine is running, make sure you are using Tygon petrol tubing as petro lwill dissolve silicon and cause blockages in your carb, type in Carb needle lock on ebay for a choice of needle locks, prestwich is the cheapest Cheers Scoop
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
w3bby
Re: Engine starting
« Reply #8 on: May 06, 2013, 10:53:28 am »
Cheapest carb needle lock, two bits of tygon and a zip tie............
black magic racing
Re: Engine starting
« Reply #9 on: May 06, 2013, 10:56:39 am »
   fully agree with that one  {-) {-) {-)
scoop
Re: Engine starting
« Reply #10 on: May 18, 2013, 05:25:18 pm »
Yeah but if you pull the zip tie too tight it bends the needles  O0
Scoop
Page created in 0.044 seconds with 16 queries.
